39,445 Members 1,489,411 Posts
Felicia Cutting out!
This is a discussion on Felicia Cutting out! within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Tonight my felicia cut out as I went to pull away, which caused it to stall. It took me ages ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 07-11-2005, 19:08   #1
"Bones"
flatfourburble's Avatar
Members Car: Fabia vRS
Tonight my felicia cut out as I went to pull away, which caused it to stall. It took me ages to get it started again, once started on the journey home it was rough and kept trying to cut out, say when changing gear up or down. Also when braking/coming to a stop.
Anyone have an ideas? Would changing the plugs and leads be a good start?
Help as I need it for work tomorrow d'oh!
Oh to have the internet back..................oh have I missed it
flatfourburble is offline
Old 07-11-2005, 21:37   #2
Members Car:
chaces are you sucked a seal in out of the carb
you have to rev its tits off to change gear? its a pig but its not serious
MY Attitude YOUR problem
skoda.fr is offline
Old 07-11-2005, 21:41   #3
"Bones"
Anything else it might be. Any home tests I could try before taking it to a garage? Could it just be poor fueling?
Old 08-11-2005, 00:26   #4
Cupra Bush King
Lummox's Avatar
Images: 2
Could well be down to a coolant temp sensor giving incorrect fueling.
Difficult to say without having a look.
I take it its a SPI engine?
www.unit18.co.uk
Lummox is offline
Old 08-11-2005, 10:14   #5
"Bones"
Ross it's the MPi.
Thinking about it the coolant temp sensor might be it?
I've notice the gauge goes up very quickly even though the car doesn't seem to be hot. Then it will drop again, or would that just be a faulty gauge?
Thanks ross
Old 08-11-2005, 19:10   #6
Cupra Bush King
Lummox's Avatar
Images: 2
I would certianly take a look at the sensor.
www.unit18.co.uk
Lummox is offline
Old 08-11-2005, 19:13   #7
Members Car:
I had similar symptons on my 1.3 Mpi, turned out to be the throttle air mass sensor. Expensive to replace, so hopefully not!
feliciasleeper is offline
Old 08-11-2005, 19:26   #8
Cupra Bush King
Lummox's Avatar
Images: 2
If it does end up being the MAP sensor give me a shout Mike, might be able to sort something for you.
www.unit18.co.uk
Lummox is offline
Old 09-11-2005, 10:35   #9
"Bones"
cheers mate I'll get the old haynes out and have a look
Old 09-11-2005, 14:22   #10
big k's Avatar
Members Car: that would be telling
will be temp sensor
how can me find a jet engine for me rapid ?
big k is offline
Old 29-11-2005, 00:35   #11
magnum67's Avatar
Members Car:
Re: Felicia Cutting out!
Just bought a T-reg 1.3 Magic which is in good nick but for a couple of glitches that might be connected to this thread so would appreciate some advice...
Starts from cold OK but won't restart from hot without a great deal of churning or having to resort to jump starting. Also the temp gauge won't go above the 70 mark which seems low.
Any thoughts
Member in name only... Oh dear...
magnum67 is offline
Old 29-11-2005, 14:21   #12
big k's Avatar
Any thoughts
faulty temp sensor/thermostat very common on felicity's
big k is offline
Old 30-11-2005, 13:57   #13
magnum67's Avatar
Members Car:
Ta for that. I've booked the old girl in for a service on Saturday so guess might have to replace some bits...
magnum67 is offline
Old 03-01-2006, 11:32   #14
Members Car:
All in group and this thread!
I was going to pose a similar question this a.m. but I think you may have given me the answer.
My 'V'plate 1.3 Mpi has started with a niggling fault over the festive holiday. The problem has been very similar to that described in that the car starts o.k.ish!! runs a bit lumpy until revved and the seems to stabilize. The first time the car comes to a halt or even at a gear change, when the revs drop, at this point the revs drop below tickover and the engine stalls and then is quite difficult to restart, but until now it has restarted. I'll try the temp sensor as suggested.
I am still quite new to the Skoda brigade and still havn't sorted out good suppliers and such. Has anybody got a list of good suppliers either mail order or on the tinternet.
Any help or suggestions much appreciated.
Ben.
Ben Da Menda is offline
Old 07-01-2006, 23:08   #15
blinkinink's Avatar
Members Car:
Talking Re: Felicia Cutting out!
best bet for suppliers is:
www.jhmbuttco.co.uk
all the bits and bobs you could possibly imagine. They have a downloadable catalogue too, which you can keep to look up things when ur not online, handy!
all is good
have used them before
blinkinink is offline
Old 08-03-2006, 17:24   #16
Members Car:
also had a customer with a hard to start felicia - nothing obvious...
turned out to be the crank position sensor was covered in a layer of filth - once cleaned and refitted it was fine...
bizarre to diagnose... but didnt cost any parts!
worth the 5mins it takes to check it, as it is v.easy to get.
Any one desperate for old skoda bits/hard to find stuff?
I may be able to help you. I am surrounding by the bl88dy things here in Cz!
blankczechbook is offline
Similar Threads
I Beat a 300hp Escort Cosworth in My 1.3 felicia, and he was trying!!!!! ugluk Off Topic and Chit Chat 19 04-04-2006 22:17
Felicia diesel exhaust skoda.fr Favorit, Felicia, Fun and Forman 1 18-10-2005 18:28
Mod Felicia, or buy sumthing else. subsidian Favorit, Felicia, Fun and Forman 8 23-08-2005 11:26
Felicia questions.... beastieboy Favorit, Felicia, Fun and Forman 46 12-07-2005 15:39
