Felicia Diesel Starting Problem
This is a discussion on Felicia Diesel Starting Problem within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; I have a 99 Diesel GLI Felicia and when it gets warm e.g normal running temp and I turn the ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 30-06-2008, 01:50   #1
TURBO4NI's Avatar
Default Felicia Diesel Starting Problem
I have a 99 Diesel GLI Felicia and when it gets warm e.g normal running temp and I turn the engine off it becomes hard to start and the heater light does not come on..
Anyone got any ideas please..??
The only constant is change..
TURBO4NI is offline
Old 30-06-2008, 11:46   #2
KenONeill's Avatar
Default Re: Felicia Diesel Starting Problem
Does the starter motor spin at the same sort of speed as when the engine is cold?
If not, suspect starter connections or solonoid.
If so, suspect engine temperature sensor.
KenONeill is offline
Old 30-06-2008, 13:09   #3
savage's Avatar
Temperature sensor
45mph is fast enough to kill you yet slow enough to make you think it's safe.
savage is offline
Old 30-06-2008, 21:08   #4
TURBO4NI's Avatar
The starter motor does spin at the same speed but for a longer period. Sometimes it starts, sometimes it doesn't..
TURBO4NI is offline
Old 30-06-2008, 22:15   #5
rigsby's Avatar
Deffo temp sender , put in one from a 1.3 and your problems should stop
I DONT WANT TO DIE A GROWN UP!!!
rigsby is offline
Old 01-07-2008, 22:41   #6
You might like to read the posts which I submitted on this problem. It is very common, and there appear to be two answers, one immediate which really only tackles the symptoms but seems to have very few side effects, and one more permanent which involves finding a good mechanic. My experiences are well documented on the following two posts:
http://briskoda.net/forums/favorit-f...problem/77545/
and
http://briskoda.net/forums/favorit-f...re-news/86598/
If you look at them in that order, you'll find out what I found out.
Best wishes,
Mr Music
Mr Music is offline
