This is a discussion on felicia door lock swap help within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; I have a knackered door lock on drivers side Felicia 1.3, 2000. It spins on itself and does not operate ...
| Briskodian | felicia door lock swap help I have a knackered door lock on drivers side Felicia 1.3, 2000. It spins on itself and does not operate centrla locking. On inspection inside panel the lock barrel part is not turning the arm connected to it and thus operating the locking system. Can I borrow the lock from the passenger side or are they one sided ? Otherwise I am going to end up with 3 keys coz I'm too tight to have new lock matched to old key. Ian |
| ECUless | Re: felicia door lock swap help They are not handed, why not get a new lock and take the good bit off it to replace the broken bit on your lock and you won't have a different key. |
| Briskodian | Re: felicia door lock swap help Don't know which part of barrel is broke and can't be assed to take it apart. |
| Briskodian Join Date: Mar 2006
Members Car: Skoda Felicia 1.3 MPI 1998 Thanks: 15
| Re: felicia door lock swap help |
| Briskodian | Re: felicia door lock swap help Fixed the door lock yesterday, new lock, job done after a few scraped knuckles. Locks are one sided as the arm is attached, if anyone has same problem. Now I don't have to unlock from passenger anymore - hurrah. £23 all in but that was for lock with different key. |
