This is a discussion on Felicia rear disc brake conversion within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; yet again, this is a thing i've been planning to do for a while now, basically it's a case of ...
Members Car: Fabia 2.0/Felicia Thanks: 48
| Felicia rear disc brake conversion yet again, this is a thing i've been planning to do for a while now, basically it's a case of finding something suitable and putting it all together my initial thoughts are to use the rear stub axles/bearings/hubs/calipers from a 6n2 polo ![]() |
| Re: Felicia rear disc brake conversion thread i'm lead to believe that the bolt pattern for the stub axles is the same as the felicia stub axles ![]() |
| Re: Felicia rear disc brake conversion thread i've got a nice bare felicia rear axle to play with.... next job is up to the scrap yard tomorrow to see what i can find ![]() ![]() |
| Briskodian Join Date: Jan 2007 Location: Leeds
Members Car: 1994 Skoda Favorit GLXIe Estate Images: 1 Thanks: 1,120
| Re: Felicia rear disc brake conversion thread It has been done with VW Passat bits over on this thread Board Message but I'm guessing that link won't work, so sign posts to thread are http://www.skoda-forum.com/ SKODA FORUM: Technical Help & Advice->Guides & FAQ's Currently 5th post "Rear disc conversion on a Favorit." Edit: looks like guides and FAQ's are not available unless logged in. Last edited by anewman; 16-09-2008 at 20:49. |
| Briskodian Join Date: Jan 2004 Location: DONCASTER
Members Car: FELICIA FUN,FAVORIT,FABIA TDI,ESTELLE ROADSTER Thanks: 18
| Re: Felicia rear disc brake conversion thread Have a look on www.skoda-forum.com for a bloke called Ken. He has done a rear disc conversion on his favorit track car (and a lot more too). I think he used passat or golf parts
__________________ I DONT WANT TO DIE A GROWN UP! |
| Re: Felicia rear disc brake conversion thread thanks, for that guys, i'm keen not using golf stub axles because they have crap wheel bearing arrangements Last edited by TeflonTom; 29-09-2008 at 23:14. |
| Briskodian Join Date: Dec 2006 Location: Czech Republic
Members Car: Škoda Felicia Fun Thanks: 1
| Re: Felicia rear disc brake conversion thread My "version".... complet rear brakes from golf 2 GTI. You must modify brake wires.
__________________ http://www.cardomain.com/ride/2258735 |
| The Following User Says Thank You to Skury For This Useful Post: | TeflonTom (17-09-2008) |
| Re: Felicia rear disc brake conversion thread i see you have the hp coilovers too, very nice edit: that's a pickup isn't it?? |
| Re: Felicia rear disc brake conversion thread jj, my felicia fun. And rear HP coilovers are modified from coilovers for hatchback (HP don't made set for pickup) + custom springs. Rear is -60mm low.
| | #10 |
| Briskodian Join Date: Feb 2007 Location: York
Members Car: Skoda Felicia Laurin & Klement 1.3 Thanks: 62
| Re: Felicia rear disc brake conversion thread Was that just a straight bolt-on swap then plus changing the brake pipes? Looks good... Phil |
| | #11 |
| Re: Felicia rear disc brake conversion thread yeah it is, i've just come back from the scrapyard and i had a look at a mk2 golf while i was there, couldn't get the brake calipers off though because the bolts were rounded off, will go back with some more tools and have another go later |
| | #12 |
| Re: Felicia rear disc brake conversion thread edit: changed my mind again ![]() Last edited by TeflonTom; 29-09-2008 at 23:14. |
| | #13 |
Members Car: Octavia TDi110 Thanks: 65
| Re: Felicia rear disc brake conversion thread You'll find that happens more and more with some newer cars, because it saves a few seconds when bolting things up in the factory. That said, I know the Octys and Golf 4s use sealed hubs. |
| | #14 |
| Re: Felicia rear disc brake conversion thread Out of interest... if you was going to do this to a Felicia with ABS, can you simply swap over the sensor wiring? |
| | #15 |
| Re: Felicia rear disc brake conversion thread You must use GIII gti/corrado g60 brakes with ABS sensors...
| | #16 |
| Briskodian Join Date: Feb 2008 Location: cleveland
Members Car: 1997 skoda felicia 1.3mpi Thanks: 4
| Re: Felicia rear disc brake conversion thread will it make much difference changine the back brakes in terms of stopping performance?
__________________ with out dissapointment you cant appreciate victory! |
| | #17 |
Members Car: Noddy Car Thanks: 211
| Re: Felicia rear disc brake conversion thread If you happen to come across a mk2 16v stub axle on your hunt give me a shout tom .Other than that I have the complete setup in a box here
__________________ ![]() |
| | #18 | ||
| Re: Felicia rear disc brake conversion thread the polo has the abs sensor attached to the back of the hub rather than on the disc. plus the polo/lupo ones have the same wiring connector so you don't even need to change the plugs over ![]() Quote:
what set up have you got?? i will consider anything really ![]() | ||
| | #19 | |
| Re: Felicia rear disc brake conversion thread Quote:
__________________ http://www.cardomain.com/ride/2258735 | |
| | #20 |
| Re: Felicia rear disc brake conversion ![]() i know these aren't necessary but i've got some spacers to go behind the rear stub axles to widen the rear track width |
| | #21 |
| Re: Felicia rear disc brake conversion Nice idea. Amongst other things, it'll avoid the brake pulsing issues and offset change issues associated with the "normal" spacers. |
| | #22 |
| not a bird!!! Join Date: Sep 2006 Location: pixi said not to fill my box
Members Car: 1.6l felicia 1998 Thanks: 1
| Re: Felicia rear disc brake conversion now theres a good idea. sod wheel spacers. have stub spacers instead. out of intrest. how thick are they? and do you have the dimensions to hand ![]() |
| | #23 |
| Re: Felicia rear disc brake conversion Its not a new idea, plus if you make them wider at the bottom you can dial in some negative camber. |
| | #24 |
| Re: Felicia rear disc brake conversion watch out if you are doing it on drums brakes though, the brake pipes might not be long enough |
| | #25 |
| Re: Felicia rear disc brake conversion |
