This is a discussion on hall sensor within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Hi there folks its me again, can any of you knowledge laden folk tell me what roll the hall sensor ...
| Briskodian Join Date: Apr 2008
| Hi there folks its me again, can any of you knowledge laden folk tell me what roll the hall sensor plays in the life of my 96felicia lxi and what will happen should it fail? thankyou |
| Nelly the Felly Join Date: Feb 2007 Location: York
| It is the small sensor that sits on top of the gearbox and basically tells the ECU that the engine is turning... if it were to fail (as mine did) the car would turn over but wouldn't start as the ECU would think that the engine wasn't turning over and so wouldn't ignite/inject fuel. You having starting problems or just curious? Phil |
| The Following User Says Thank You to philje123 For This Useful Post: | bernardo (30-04-2008)
| | #3 | |
| Quote:
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Which Felicia do you have? If its a 1.6 its in the distributor and very common to fail.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| The Following User Says Thank You to Lummox For This Useful Post: | bernardo (30-04-2008)
| Briskodian Join Date: May 2008
| A Hall effect sensor,s job in any situation is to sense magnetic pulses so may be found in several ECU circuits and sensors |
