This is a discussion on i'm going to make my own coilovers within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; edit: final finished coilover unit right, i've decided to have a go at making my own coilovers... where can i ...
| edit: final finished coilover unit ![]() right, i've decided to have a go at making my own coilovers... where can i buy those threaded spring seat/conversion kits from???
__________________ vorsprung durch czechnik Last edited by TeflonTom; 18-08-2008 at 20:36. |
| not a bird!!! Join Date: Sep 2006 Location: pixi said not to fill my box
| rally design, i think |
| off hand, do you know what the springs rates are on the hp units??
__________________ vorsprung durch czechnik |
| Nelly the Felly Join Date: Feb 2007 Location: York
| Right... im officially feeling stupid and confused! What exactly are the coilovers? Are they the top bits of the suspension? Phil |
| Briskodian Join Date: Jun 2003
__________________ ________________________________________ Some times I just feel like smiling. |
| Yay... I get it now! Are there any other systems available for the Felicia? My struts a re getting pretty rusty and starting to knock... needs replacing soon so might as well do it in style! Phil |
| Can you keep us posted Tom? It sounds like an interesting project. |
| off hand i dont know the spring values. but iirc the hp's are 75% stiffer than the standards. |
| How do you even go about making your own? A mish mash of differnt parts put together and fettled or parts made custom from scratch? Phil |
| | #10 | |
| Quote:
__________________ vorsprung durch czechnik | |
| | #11 |
| Ah right... so you would use your original and standard suspension setup but make it so that you can adjust the height? |
| | #12 |
| not quite no.... i've ordered a pair of these inserts from jkm koni inserts, i'm going to collect them tomorrow, with these you basically remove all of the innards of the original strut and put this in instead
| | #13 |
| Ah right... so your just basically left with the original springs and new shocks. What about the cups that are prone to rust? Will they be replaced? Its all very complicated this... thats why i'm liking the idea of the HP set... so so damn expensive! lol |
| | #14 |
| the height adjustable kit replaces the original spring perch with one that can be moved by rotating it around the body of the strut, this also disposes of the original spring too and uses a 2.25" spring, these springs are available in many different lengths and rates
| | #15 |
| I see... So it does end up being a total replacement of all the components! Is it diy'able or would i need to be able to compress the springs etc? Maybe you wouldn't mind sharing the prices of the components and giving a total price of the build? Phil |
| | #16 | |
| Quote:
i will make one set as a protoype, and if they are any good i will think about making some more... i will take some photos of the different stages as i do it
| The Following User Says Thank You to TeflonTom For This Useful Post: | philje123 (11-06-2008)
| | #17 |
| That would be bloody marvelous of you... could make some money out of this if it works... im sure there's plenty of folks after a decent suspension upgrade without trying to source the HP set! Phil |
| | #18 |
| to be honest i've looked at the hp set and they dont look all that good, they seem a bit flimsy to me ![]()
| | #19 |
| You'd need spring compressors yes, but you can buy or hire a set of them. As Tom says, the big issues are with components that need machining or welding. |
| | #20 |
| Don't think i would be able to do it myself... never welded anything in my life and don't have access to such equipment any way. So my options are to do something like this but have a garage do it for me... or buy a complete set. Phil |
