This is a discussion on my wheels dont fit within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; i brought some tsw wheels today and the hole centres dont match up, the ones on the wheel are to ...
| Briskodian Join Date: Jun 2008 Location: Wolverhampton
Members Car: skoda favorit, 1.3 glxie Thanks: 30
| i brought some tsw wheels today and the hole centres dont match up, the ones on the wheel are to big by about 5 mill are there any kits available to make the wheels fit? |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
Members Car: Skoda Octavia vRS Thanks: 216
| Re: my wheels dont fit Yes... You need some spigot rings |
| Re: my wheels dont fit just searched on spigot rings and they just look like rings for the centre of the wheel :S nothing to do with hole centers? the actual bolt holes dont line up |
| Re: my wheels dont fit Strange? You sure they're actually too big? The holes will be tapered inwards |
| Re: my wheels dont fit the holes on the wheels are spaced out wider than the holes on the car, in effect the holes are half covered by the wheels ![]() |
| Briskodian Join Date: Feb 2007 Location: York
Members Car: Skoda Felicia Laurin & Klement 1.3 Thanks: 62
| Re: my wheels dont fit Maybe you bought the wrong wheels then? You sure they were designed to fit on the felicia? Phil |
| Re: my wheels dont fit i brought them from a bloke at work who had them off a ford, said they should fit the same.. but they dont does anyone know of any kits that i can make these wheels fit with? or should i just sell them and buy some that do fit? i have some series one rs turbo wheels off a fiesta i beleive for sale all in need of refurb, 2 good avon tyres on 2 2 naff odd brands on 2 others and one i started rubbing down myself and never had time to finish if anyone knows of anyone who wants wheels? £40 to get rid of them |
| Briskodian Join Date: May 2008 Location: sheffield
Members Car: 1.6 slxi felicia hatch Thanks: 0
| Re: my wheels dont fit What you need are pcd adapters, these change the pitch circle diameter and then the holes will line up....BUT, these obviously add width and this will dramatically change the offset of the wheels which can then start rubbing on wheel arches or suspension mountings. The simple and sensible answer is just flog the wheels and find some that fit. The things you need to look for are a PCD of 4 x 100, which is 4 holes with a measurement of 100mm between the centre of diagonal holes. (ford are 4x108) then to get the offset correct you should be finding ones with an ofset (often stamped ET on the wheel) of 38. 35 is a common offset and would actually make the stance of the car 3mm narrower per side than 38. there are loads of cars with the same pcd, but watch out for the offset as hondas and rovers often use an ofset of 25 which would potentially start hitting suspension etc as it would be over 10 mm further into the car, so you'd then need wheel spacers etc. this is a great site for lists of similar fitments:Alloy wheel fitments and pcd's. and further reading is available at:The Car Maintenance Bibles Last edited by mattstead; 17-06-2008 at 20:56. |
| Re: my wheels dont fit They wont fit, Ford wheels have a PCD of 108mm and VW have a PCD of 4x100. |
| | #10 |
| Briskodian Join Date: Jun 2008 Location: Cambridgeshire
Members Car: Vauxhall Astra 1.8 16v Thanks: 23
| Re: my wheels dont fit Lummox your a god
__________________ ![]() Craig Laurence ![]() ![]() |
| | #11 |
| Re: my wheels dont fit Its only th same advice as Matt has correctly given above me. However i wouldnt bother with PCD adapters on a Felicia, just get the right wheels. Hundereds to choose from. Anything from a MK2 Golf etc will bolt straight on, and look pretty cool. Nice set of BBS RA alloys as fitted to the GTi would be well swish. |
| | #12 |
| Re: my wheels dont fit Some of those BBS wheels look good... i know because i've got them... were fitted standard to some felicias too... but would probably be able to grab some off an old Golf etc. See... they look pretty smart.. these are just 14" though... so could probably go for some 15's and they'd look a bit better! ![]() |
| | #13 |
| Briskodian Join Date: Jan 2007 Location: Leeds
Members Car: 1994 Skoda Favorit GLXIe Estate Images: 1 Thanks: 1,118
| Re: my wheels dont fit I believe anything that fits the new BMW mini should fit too? |
| | #14 |
| Re: my wheels dont fit [quote=philje123;1327550]Some of those BBS wheels look good... i know because i've got them... were fitted standard to some felicias too... but would probably be able to grab some off an old Golf etc. See... they look pretty smart.. these are just 14" though... so could probably go for some 15's and they'd look a bit better! Looks nice, they aint RA's though. ![]() |
| | #15 |
| Re: my wheels dont fit No they're not... but im glad i dont have to clean those... mine are bad enough! |
| | #16 |
| Briskodian Join Date: Jan 2004 Location: DONCASTER
Members Car: FELICIA FUN,FAVORIT,FABIA TDI,ESTELLE ROADSTER Thanks: 16
| Re: my wheels dont fit not unless you play with the hole in the middle, as it is smaller , and wont go straight onto a vw hub. mk 1 beemer 3 series ,4stud wheels will though
__________________ I DONT WANT TO DIE A GROWN UP! |
| The Following User Says Thank You to rigsby For This Useful Post: | anewman (17-06-2008) |
| Will these wheels fit? | Steve Sanders | Fabia I | 12 | 18-09-2008 15:39 |
| Will these wheels fit? | dstev2000 | Octavia II | 26 | 06-06-2008 13:56 |
| Will these wheels fit? | Richy Fitt | Octavia I | 1 | 15-05-2008 18:11 |
| Will these wheels fit?? | wozza-vrs | Fabia I | 30 | 08-10-2007 08:44 |
| wheels...which fit? | landwomble | Superb | 18 | 17-11-2006 10:10 |
