39,349 Members 1,485,787 Posts
Need Help Guys! Felica rear springs
This is a discussion on Need Help Guys! Felica rear springs within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Pretty new to this so bare with me. I have a 1997 Felica LXI Plus. Looking to replace the orginal ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 15-08-2007, 16:58   #1
Members Car:
I have a 1997 Felica LXI Plus. Looking to replace the orginal rear suspesion cos it's seen better days and i get the impression the MOT centre will laugh it out the garage next month. Orginals from Skoda are about £90 for the set (springs and dampers) but wondered if i can get lowing springs from anywhere or you guys know of alternatives that will fit i.e Volkswagon one (was thinking MKII golf but icould be way off).
Anyone who is mad enough to of done it before (the response i get from most none Skoda owers) and can help, your advice would be great.
TheBigMan is offline
Old 15-08-2007, 17:10   #2
Jaymz's Avatar
Members Car: Skoda Felicia GLXI
Re: Need Help Guys! Felica rear springs
hello there i also want to lower my felicia nice to know other people want to as well, i was having quick look round on net and found this dunno if its any help 87-104 Skoda FELICIA Lowering Springs by Pi from eDirectory.co.uk online shop
just browse the net looking on sites which sell them i know iv got a link on my home pc (im in work) ill post them when i get home for you. either this or you could pop into your local garage and ask bout them , they might be able to order some or at least let u know what correct type u need.
Pooky Power!!
Jaymz is offline
Old 15-08-2007, 17:40   #3
andy2407's Avatar
Members Car: Yellow Fabia vRS
Might be worth having a look at Butts of Bawtry - Homepage
The future's bright
The future's mellow
Now with a little zest of Washbrook added
andy2407 is offline
Old 15-08-2007, 18:01   #4
Jaymz's Avatar
yeah that was the site i was goin to recommend
Pooky Power!!
Jaymz is offline
Old 15-08-2007, 22:35   #5
not a bird!!!
pinkskud's Avatar
Members Car: 1.6l felicia 1998
mine is lowered. 35mm on s-max springs, but if your doing the dampers aswell would be worth getting estate dampers (more damping force to counteract the stiffer springs) or, the HP sporting set from Homepage
pinkskud is offline
Old 15-08-2007, 22:47   #6
Briskodiodion
TeflonTom's Avatar
Members Car: Fabia 2.0/Felicia
you can get lowering springs from spax too about £100
TeflonTom is offline
Old 16-08-2007, 23:38   #7
Members Car: mk1 fav
jamex springs from motorsportworld in scotland. mail order, and the cheapest available. i did 4 hours straight searching one night, i KNOW they're the cheapest.
dont hold your breath waiting on any lowering shocks though. id suggest going straight to GAZ.
if you only want back lowering springs (-35/40) and standard shocks, i can set you up a treat with some brand new items for about £125 plus delivery.
surprising_skod is offline
Old 17-08-2007, 01:42   #8
I have H&R springs (45/15) on felicia. Not really comfortable ones but handling is great.
Not sure whether eibach still produces springs for felicia (on their .de site felicia is on the list but dealers are not so sure about it ). Eibach's should be the best option.
Also, Platimex should have something. Don't have any idea about quality/durability/handling.
Regarding the suspension, I have Kayaba (kyb) gas dampers. Better than original but not so great. If I remember correctly, Koni (special red) should have some dampers for felicia. Sachs also, but a bit pricey.
Djuro is offline
Old 04-10-2007, 19:39   #9
Members Car:
I'm thinking of ordering some of these: SPAX / SSX Springs / Skoda Felicia LX/GLX ; 12/94- ; -35mm / Euro Performance Car Parts
This could be a stupid question, but do these come as a pair? or as a set of 4?
Identiti rider is offline
Old 04-10-2007, 22:46   #10
not a bird!!!
pinkskud's Avatar
usually come as a set of 4, and they look like a full set.
mind you. it dont say how much it lowers by?????
says up to 80mm. but on a felicia, if you lowered it 80mm, it would be on the floor! (trust me i know)
i'm using the HP sporting coilovers. i used lowering springs before.
the lowering springs work better with estate dampers (if you have a hatch) cuz they have more damping force.
also found on
http://skodafelicia.freeforums.org/index.php
pinkskud is offline
Old 04-10-2007, 23:40   #11
price on the coilies? GAZ want £500 to build me a set. then again i wanted 200mm drop potential
Old 05-10-2007, 00:29   #12
Members Car:
Car fitment
35mm drop me thinks.
Old 05-10-2007, 17:16   #13
not a bird!!!
pinkskud's Avatar
the coilovers are HPsporting and cost £350. but there designed for rally use, so the back end is on the floor, and the front is up a bit so it can get over stuff.
the shocks have three set ride hight positions insted of the usual threaded set-up.
i'm guna look into having some shorter spring made up for the front of mine, to get the front to sit low as!!!!!! just like the back.
as for 200mm drop, the only way to get that would be on an air-ride set-up.
also found on
pinkskud is offline
Old 05-10-2007, 18:19   #14
WoodieGuthrie's Avatar
Members Car: Totally Stock:-)
I'm seriously considering replacing the disc/pads and springs/shocks on my little bro's felly.
what would you recommend drop wise for a car ahtats quite frequently loaded fully?
WoodieGuthrie is offline
Old 06-10-2007, 10:17   #15
not a bird!!!
pinkskud's Avatar
35mm
also found on
pinkskud is offline
