39,349 Members 1,485,787 Posts
Noise in fifth gear
This is a discussion on Noise in fifth gear within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Just had the middle part of the exhaust replaced and on the way home i noticed that when i accelerate ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 30-04-2007, 17:43   #1
Vincent Vega's Avatar
Members Car: Felicia
Noise in fifth gear
Just had the middle part of the exhaust replaced and on the way home i noticed that when i accelerate the engine makes a loud whiny noise this only happens in fifth gear and sounds like its coming from the drivers side.
Any thoughts on this ?
Vincent Vega is offline
Old 30-04-2007, 18:33   #2
ECUless
fordfan's Avatar
Members Car:
Re: Noise in fifth gear
Don't use 5th, the gear retaining nut has come loose, continued use will strip the splines on the shaft and will be expensive. It is not a major job to fix and a new nut is about £5 + new gearbox oil, labour should be 1 to 1.5 hours. It is DIYable.
fordfan is offline
Old 17-05-2007, 08:45   #3
BRISKODA Staff
mannyo's Avatar
Following on from this, I can now say that my brothers car is now fixed. Was in at the skoda dealer on tuesday, cost him about £150 for the repair but at least he has the use of 5th gear again. The problem was as fordfan described the retaining nut.
Now all he needs to do is get a new clutch once he has saved up some pennies again, as apparently this one will soon be knocking on deaths door.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 03-05-2008, 11:38   #4
Members Car:
How much torque to use when attaching this retaining nut?
daggis is offline
Old 03-05-2008, 21:10   #5
rigsby's Avatar
cant be that much, as if you are removing it, it is because it has already come loose
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
Old 05-05-2008, 00:48   #6
not a bird!!!
pinkskud's Avatar
Members Car: 1.6l felicia 1998
i did this job the other week.
your gunna meed some big old spanners, i cant remember the sizes but i know you'll need some bigish ones for the drain plug and the 5th gear nut itself.
you'll also need a second jack, a trolly or bottle type will do. this is used to hold/lift/lower the gear box when you taking the gearbox mount off
once you have the mount/end cover off, you'll be able to see whitch one off not both of the nuts has come a-drift. the nuts cost £7 inc/vat each, and to be on the safe side i would recomend getting two (just in case both have gone)
your gunna need a good pin punch or cold chisle to peen the sholder of the nut and lock it in place.
i also used some gear box casing sealer compound then i put the cover back on. i dont think you really need it bit i did it anyway.
once the box is all back to gether and the mount bolted up. you'll need to re-fill the box with transmition fluid. when stood at the front of the car, and looking at were the speedo drive goes in, on the left of the speedo drive you'll see a little skrew. undo this skrew and slide out the falk shaped retaining plate. the speedo drive should then just pull out. use the little speedo gear as a dip stick to check the oil level.
o yer and you'll need a bit of hose pipe attached to a funnal to fill the box again.
hope this helps
also found on
http://skodafelicia.freeforums.org/index.php
pinkskud is offline
The Following 2 Users Say Thank You to pinkskud For This Useful Post:
anewman (30-05-2008), rigsby (05-05-2008)
Old 06-05-2008, 22:52   #7
Briskodiodion
TeflonTom's Avatar
Members Car: Fabia 2.0/Felicia
i use a syphon pump to do mine approx £5 off ebay and it makes it so much quicker
the gearbox should take about 2.5 litres of oil
TeflonTom is offline
Old 07-05-2008, 19:39   #8
not a bird!!!
pinkskud's Avatar
good call tom
also found on
pinkskud is offline
Old 09-05-2008, 22:46   #9
Members Car:
Thanks guys, I really appreciate all the help!
Took of the end cover today, only to find none of the nuts are lose
I have 5th gear whining, and it jumps out of gear, so I really thought this was it..
Guess I should get myself a new gearbox then.. Crap..
daggis is offline
Old 09-05-2008, 23:44   #10
Briskodiodion
TeflonTom's Avatar
i expect the bearings are gone then
