This is a discussion on o-ring fuel filter within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; HELP! Just fitted a new fuel filter - are there supposed to be two rubber o-ring seals? There is one ...
| Briskodian Join Date: Jun 2008
| HELP! Just fitted a new fuel filter - are there supposed to be two rubber o-ring seals? There is one that came as part of the new filter on the neck, where the control valve sits, half way down: is this the one the Haynes manual is referring to? . There seem to be grooves for two seals though. Thanks |
| ECUless Join Date: Mar 2005
| There usually are, assuming a diesel. Two O rings that go on the valve, a blue and black if I recall correctly. |
