39,349 Members 1,485,783 Posts
PinkPolo - Felicia 280 & 239mm brake conversion kit
This is a discussion on PinkPolo - Felicia 280 & 239mm brake conversion kit within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; I've just translated that Czeck/Slovenian stuff about a big brake conversion kit & here's the link: Tuning - Športové brzdové ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 19-11-2007, 23:12   #1
Psyzygy's Avatar
Location: Behind the wheel of a small automobile somewhere in the East Midlands
Talking PinkPolo - Felicia 280 & 239mm brake conversion kit
I've just translated that Czeck/Slovenian stuff about a big brake conversion kit & here's the link: Tuning - Športové brzdové kotúče nemeckej kvality - ZIMMERMANN !
This is the original 1.6 Felly turbo too: ŠKODA techweb > vše o Škodovkách (No, I'm not going to attempt translation
Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt )
Psyzygy is offline
Old 20-11-2007, 00:28   #2
not a bird!!!
pinkskud's Avatar
Members Car: 1.6l felicia 1998
Re: PinkPolo - Felicia 280 & 239mm brake conversion kit
thank you.
any chance yo could work out what ECU that turbo felicia is using????
also found on
http://skodafelicia.freeforums.org/index.php
pinkskud is offline
Old 20-11-2007, 03:49   #3
Psyzygy's Avatar
It's got a thoretical top end of 200kph, dyno'd at 185k - 81.2 kW - 109 bhp running 7 bar on an Audi 2.2 turbo. Castrol TWS 10W-60.
The injection system is off an Audi 2.2 turbo too. 8 injectors. It might look a bit rough & ready, but it does the job.
As for ECU... He's got it all running off a laptop which he'll install in the car so he can fiddle with it as & when he likes. I think there's something about an extra memory module but it's not named.
Ceramic clutch, custom manifolds, quiet(ish) exhaust, no flash bodywork mods and here's a link to the dyno stats (in Slovakian of course! ) in pdf form http://skoda.panda.cz/obrazky2/442.pdf
As for any details about the uprated brakes & suspension, I drew pretty much a blank and tbh the Zimmermann brakes link is a bit of guesswork too. The Slovaks seem to rave about them a bit and they're dirt cheap in the States. Virtually unknown here in the UK.
Good grief! What time is it?
Psyzygy is offline
Old 20-11-2007, 03:53   #4
207/340
Wardy's Avatar
Members Car: Skoda Fabia vRS
I'm afraid I don't know a lot about the Felicia, but are the underpinnings not based on a Polo Mk4 (6N/6N2) ? If so, you could use the brake carriers from a Corrado G60 and then bolt 280mm discs straight on the front?
Sorry if this is stating the obvious, but it's what I did with my 6N2 Polo GTi and made a huge difference
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 20-11-2007, 04:09   #5
Psyzygy's Avatar
From what I've read Steve - and see TeflonToms thread about the Q-Felicia http://www.briskoda.net/forums/proje...ight=q+felicia with regards the brakes - the Felicia is based on the earlier Favorit & has nothing whatsoever to do with any VW designed or built car before 1999. http://www.briskoda.net/forums/felic...t-based/92587/ for confirmation.
I don't use the brakes very much anyway, so it's not of much concern to me
Psyzygy is offline
Old 20-11-2007, 04:24   #6
Psyzygy's Avatar
Oh and apparently you need 15" rims for 280mm disks & they barely fit without bodywork mods. It's late, I'm tired & might be wrong...
Psyzygy is offline
Old 20-11-2007, 11:50   #7
Briskodiodion
TeflonTom's Avatar
Members Car: Fabia 2.0/Felicia
those old skool audi's wouldn't be a very good choice as a donor car imho, the turbocharger on those had an external wastegate which would be a headache becasue you need extra pipework, i cant see how they would use the injection gear either being a 5 cylinder engine, the ecu would simply be unable to run a 4 cylinder engine
TeflonTom is offline
Old 20-11-2007, 16:25   #8
Psyzygy's Avatar
Ahhhh that's what one of those weirds were... Wastegate (considering that the Slovak words for mudguard and dashboard are the same and I don't speak a word of it and I was translating from an online dictionary AND it wasn't a technical write-up, I think that even getting 8 injectors wan't bad ).
I couldn't tell which pump he used specifically, though it did say something about ditching some injection pipework (hence the untidiness) and there was a lot about the exhaust & other pipework that was indecypherable.
He didn't use the Audi ECU, he was mapping it with presumably VAG diagnostics running on a laptop and some ancilliary back-up storage.
Probably not a set-up for the purist.
Oh and I only really went there to see if there was anything about a kit to do what you're doing with 280mm brakes, which look great btw!
Psyzygy is offline
Old 20-11-2007, 19:03   #9
Briskodiodion
TeflonTom's Avatar
if you want a set of 4 pots for a felicia i reckon about Ł450 should cover it, maybe less, pm me if you are interested
Old 20-11-2007, 19:27   #10
not a bird!!!
pinkskud's Avatar
Steve
i was working on this, but as said befor, the felly is no polo.
i'v managed to get the 280mm corrado disks to fit (not the first to) but i was working on the G60 caliper/carriers but there a total no go, there never gunna fit. there are clearnce isues.
so, im thinking of the willwood calipers like tom.
also found on
pinkskud is offline
Similar Threads
Felicia 1.6 - Induction Kit & Wheels jamesdu Favorit, Felicia, Fun and Forman 17 10-07-2006 14:08
HID Conversion Kit? Mull3tt Styling and Car Care 14 27-07-2005 12:20
Brake Conversion kayode Fabia I 0 03-05-2005 20:15
AP brake conversion adaadams Maintenance & Performance 27 27-11-2004 09:40
