This is a discussion on Prising brake fluid reservoir from master cylinder, any tips? within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Well I've managed what I believe to be the most difficult bits, got the servo and mc out. I have ...
| Briskodian Join Date: Jan 2007 Location: Leeds
| Well I've managed what I believe to be the most difficult bits, got the servo and mc out. I have tried for ages to remove the reservoir from the mc but it won't budge. I have tried wedging a screwdriver between them but I fear if I put further pressure on I will damage the reservoir, so was wondering if anyone had any tips. I tried to buy a new reservoir but Skoda dealer says they no longer sell them. Oh and I guess the obvious thing to come after that is to how to push it in. Hopefully that will be easier and I assume a little brake fluid on the seals will help it slide in. Thanks in advance. |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Isnt there a pin securing it to the m/c. usually is.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| There's just 2 rubber seals holding it in place. Can't see any other assemblies like a pin. |
| Got a picture?
| Be brave then and pull.
| Cheers Lummox. Absolute brute force wins ![]() |
| ECUless Join Date: Mar 2005
| Would some hot water on the old master cylinder help? Theory, that it might expand it slightly, not on the reservoir as it might soften it up. |
| Friskodian Join Date: Nov 2007 Location: Deep Space 9
| My mechanic used brute force and a big screwdriver to proze the reservoir off the old one and it just slot onto the new master master cyl. I cant see any clips you have to hold either. Cant remember what mine was like ![]() but the seal has to be pretty tight otherwise you'd be losing fluid and letting air into the system. So may just need a good tug. Last edited by Captain Sisko; 15-07-2008 at 20:56. |
