This is a discussion on Rear Speakers on My 1998 Felicia *help* within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Well...first of all...Hi Ya'll....i just bought a Skoda Felicia 1998 and well...since i got a craze for music i want ...
| Briskodian Join Date: Aug 2007 Location: Patreksfjörður,Iceland
| Well...first of all...Hi Ya'll....i just bought a Skoda Felicia 1998 and well...since i got a craze for music i want to improve the sound of music in my car...so i'd be thankful if anyone could give me some details on how to implant wires for my rear speakers....and exactly what kind of speakers would be good.... speakers that get "fitted" or speakers that get "screwed" on the "thingy for the trunk so stuff doesn't fly to the back of someone if you get in a crash" <-don't know what that thingy is called in english... Sincerely, DJOli - Iceland... |
| Re: Rear Speakers on My 1998 Felicia *help* there should be some wires for the rear speaker allready connected to the back of the radio, they are terminated behind the front kick panels in the front footwells, it should be easy to splice on some wires and run them to the back of the car from there |
| The Following User Says Thank You to TeflonTom For This Useful Post: | DJOli (05-08-2007) |
| Re: Rear Speakers on My 1998 Felicia *help* what are front kick panels?...and footwells are where? |
| Re: Rear Speakers on My 1998 Felicia *help* the kick panel is the little triangle of plastic by your feet when you are sat in the front of the car |
| Re: Rear Speakers on My 1998 Felicia *help* i don't really get it...what triangle? |
| Re: Rear Speakers on My 1998 Felicia *help* i snapped some pictures.... ![]() ![]() ![]() ![]() |
| Briskodian Join Date: Mar 2006
| Re: Rear Speakers on My 1998 Felicia *help* |
| Re: Rear Speakers on My 1998 Felicia *help* so do i...have to rip that thing apart or? |
| | #10 |
| Re: Rear Speakers on My 1998 Felicia *help* or do i just need to take out the front speakers and reach inside? |
| | #11 |
| | #12 |
| Re: Rear Speakers on My 1998 Felicia *help* how do i "unclip" it? |
| | #13 |
| Re: Rear Speakers on My 1998 Felicia *help* if you just carefully pull on it, it should come off easily |
| | #14 |
| Re: Rear Speakers on My 1998 Felicia *help* how do i "pull" a thing like that? |
| | #15 |
| Briskodian Join Date: Jan 2007 Location: Newtown Wales
| Re: Rear Speakers on My 1998 Felicia *help* I would pull up the side trim by the door (this unclips) - my kick panels were held on by one small philips screw. |
| | #16 |
| Briskodian Join Date: Jan 2004 Location: DONCASTER
| Re: Rear Speakers on My 1998 Felicia *help* sorry to offend but me think someone taking the p155 considering the english in his first post
__________________ I DONT WANT TO DIE A GROWN UP! |
| | #17 |
| | #18 |
| Re: Rear Speakers on My 1998 Felicia *help* would somebody mind telling me what p155 is? except that in the "pc language" pi55 stands for ****....anyway....is my english too bad or.... |
| | #19 |
| | #20 |
| Re: Rear Speakers on My 1998 Felicia *help* then what does P155 mean ? atleast...to you....else than ****....xD.... |
| | #21 |
| Briskodian Join Date: Jul 2007
| Re: Rear Speakers on My 1998 Felicia *help* They reckon you are extracting the urine - taking the Mickey, being sarcastic et al. I, however, reckon that your are merely a visitor to our shores who uses American English. I have recently had various bits of my car apart with the express intent to replacing my speakers etc. The way to get to the wiring for the rear speakers is that you open the front doors of your car. Running lengthways from front to rear you will see a bit of plastic alongside the seat on top of the sill (bottom part of the door). Have a look at this and you will see that it overlaps the kick panel indicated by the red arrow in the pictures above. Using a lever of some description (I used a flat bladed screwdriver) go to the front of the sill panel and gently lever it up slightly. You’ll feel it give and lift up. When it does, have a look under this panel on the kick panel and you will see a cross head screw (commonly called a Phillips head screw). Undo this and it will allow access to the area behind the kick panel. On the drivers side of a right hand drive car the connector for the rear speakers is hanging loose. The passenger side connector is tidied up by a bracket. They are easy enough to find. Have your stereo on and you will be able to hear when you disconnect your front door speakers. The rear speaker connectors are exactly the same. All you need to do is use a connector to these wires (I’d recommend cutting the wire, putting a useful connector on – not the Skoda one – and suitable connectors on your speaker wires) and gently pushing the wires underneath the various bits of trim on the way to the back of the car. As for what speakers, well – the world is your oyster. On advice of a Briskodian I fitted half decent component speakers to the front of my car and it has improved the sound no end. You can find a rough guide to speakers here. I think I may even just go for a subwoofer in the back of mine to beef up the bass. The bit of trim you referred to as stopping stuff coming at you is called a Parcel shelf. You can cut into those and mount a pair of 6 x 9” speakers. You have to be aware though, that these are easily stolen…. A good set of component speakers up front may make the difference you want, although there isn’t a lot of room for creating a decent bass reproduction. HTH S |
| The Following User Says Thank You to Stunts For This Useful Post: | DJOli (07-08-2007) |
| | #22 |
| Re: Rear Speakers on My 1998 Felicia *help* okay...thank you very very much for clearing that out for me....dammit it thought i was going to go mad or something...anyway....yeah....thanks for giving me those details & thank you all for Commenting!. Sincerely, DJOli |
| | #23 |
| Briskodian Join Date: May 2007 Location: Wexford
| Re: Rear Speakers on My 1998 Felicia *help* The rear speakers in my Felicia Combi are quite good, but maybe there aren't similar sized "blanks" in your hatchback. If they are, you could get these speakers out of a good scrap estate. |
| | #24 |
| Re: Rear Speakers on My 1998 Felicia *help* The back of the estates are quite different to hatchs - they have additional space for rear speakers, which the hatchs don't |
| | #25 |
| Re: Rear Speakers on My 1998 Felicia *help* and uh...then again onto "clipping" that triangle thingy into place...my dads' trippin and wants me to put that triangle thingy covering those wires back into place.... some help please... |
