This is a discussion on riiiiip there it goes again!! within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Ah bo*****ks Changed the front wishbone balljoints earlier in the year and car has been creaking like a old pram ...
| Briskodian Join Date: Oct 2006 Location: Newcastle upon tyne
| Ah bo*****ks Changed the front wishbone balljoints earlier in the year and car has been creaking like a old pram when turning right. I suspected that the balljoint had dried and i was right. Luckily i drilled out the rivets on the wishbone so in theory £7 and Mr Jorily should sort it.......famous last words eh!! Oh well at least it wasn't the steering rack or anything pricey ![]() ![]()
__________________ Skoda 1.3GLi 1998 now reading LXi on the back due to tailgate swop. Bought for £30 and still going strong |
| Briskodian Join Date: Mar 2008
| how easy is to change the ball joints and who is mr jorily |
| Briskodian Join Date: Jan 2007 Location: Leeds
| Mr Jorily is on ebay and www.jorily.com ![]() |
| When i say I drilled out the rivets, what i should have said is my friendly garage did it!! I couldn't free the balljoint despite undoing the pinch bolt successfully!! I got pissed off gave my garage the balljoints gave them £50 and set them on it. Hopefully i will be more successful this time!! Skoda Favorit/Felicia Bottom Ball Joint-NEW on eBay, also, Skoda, Car Parts, Cars, Parts Vehicles (end time 11-Jul-08 18:19:33 BST)
| can the ball joints just be bolted on to the wishbone or do they have to be riveted back on |
| Briskodian Join Date: Sep 2006 Location: Walsall
| On older Golfs they are riveted originally, but it's OK to bolt new ones on.
__________________ -- Chris ---------------------------------------------------- The Devil may care, but I don't mind. |
| any bolt of the right diameter or do they have to be hardened steel |
| Briskodian Join Date: Dec 2007 Location: SE London
| Any high tensile bolt, which means Grade 8.8 or higher. Most normal bright or black steel hexagon head bolts will have either 4.8 or 8.8 in raised type on the head. 4.8 is low tensile, which is fine for stuff like fixing trim in place. From memory I think you need M8 by 25mm for the balljoint. Torque will be about 30ft lb. |
| thanks for that info. how easy is it to change the bushes in the wishbone, is a press needed or can it be done with sockets and a hammer /vice |
| | #10 | |
| not a bird!!! Join Date: Sep 2006 Location: pixi said not to fill my box
| Quote:
yes but its bloody ard work. better of getting a new wishbone with bushes in it for £45ish. | |
| | #11 |
| gonna fone around tomorrow for a wishbone, thanks for the help |
| | #12 |
| | #13 |
| does jorily have a phone number? |
| | #14 |
| It's on the contact us page. Can't say I've ever seen an 05*** area code before though |
| | #15 |
| it's 05 becuase it's a BT Hub phone, still a landline though |
