This is a discussion on Sloppy gear stick (Felicia) within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Why has the gear stick on my Felicia become sloppy.It feels as if it is in neutral even though a ...
| Briskodian Join Date: May 2007
| Why has the gear stick on my Felicia become sloppy.It feels as if it is in neutral even though a gear is selected.Is there some sort of bush in the gear steady rod that has perhaps become damaged?Has anybody any ideas? |
| Briskodian Join Date: Jan 2007 Location: Leeds
| It's unlikely to fail or cause any damage, but if you prefer it to be firmer, and not end up rubbing the knees of passengers, the linkage needs sorting. Oh, is the sloppy movement just left to right? (As that's what mine is like at the moment - not got around to trying to sort it yet.) Last edited by anewman; 04-07-2008 at 22:33. |
| Friskodian Join Date: Nov 2007 Location: Deep Space 9
| Mines the same but it doesn't slip out of gear. If you really want to feel sloppy then drive my uncles Corsa!!! |
| I had a Felicia Estate that had a very sloppy gear leaver - I took it to a dealer who said there was nothing wrong with it. Four days later the bottom of the leaver snapped off and I was left with no gears. Had to put it into a gear by getting under the car and pushing the rods directly and then start the car with the clutch down and limp it home (which fortunately was only 2 miles). I should add that this particular car had done over 300k! |
| Briskodian Join Date: Jun 2008 Location: Northern Ireland
| my pickup is yhe same.......its a lot like stirring soup!!!!! never fails to go in or out of gear. 140k on her
__________________ pickup van 1.6mpi £190 workhorse! earning her keep!!! 35+MPG |
