Smells from charcoal canister
This is a discussion on Smells from charcoal canister within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Hi, my 1998 1.3mpi Felicia has started making strange smells when it gets hot. These seems to come from the ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 23-07-2008, 16:15   #1
Default Smells from charcoal canister
Hi, my 1998 1.3mpi Felicia has started making strange smells when it gets hot. These seems to come from the charcoal canister ( emissions control) situated next to the battery. It also fizzes and hisses quietly from the canister when the engine is hot. Is this normal? Can / should the charcoal canister need replacing?
Thanks.
thekrankis is offline
Old 23-07-2008, 17:24   #2
Briskodiodion
TeflonTom's Avatar
Default Re: Smells from charcoal canister
maybe yes... have you checked the purge valve is working??
TeflonTom is offline
Old 23-07-2008, 18:10   #3
Thanks, how do I check the purge valve?
Old 23-07-2008, 19:56   #4
anewman's Avatar
Haynes says to check the resistance across the terminals. Unplug, get out a multimeter and it should apparently read at between 35 and 55 ohms at 20 degrees celcius. This is for the Favorit but I suspect the Felicia will be similar values.
94 Favorit GLXIe Estate
anewman is online now
Old 02-08-2008, 13:38   #5
The smell turned out to be coming from an overheated battery due to a faulty voltage regulator. A new alternator ( also damaged) fixed it and the battery seems to have survived the overcharging. Hopefully the ECU will be OK too, it seems fine at the mo.
Old 02-08-2008, 16:46   #6
Briskodiodion
TeflonTom's Avatar
yeah, the ecu has a built in circuit for regulating the supply voltage
