stalling felicia pickup
This is a discussion on stalling felicia pickup within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; anybody any ideas on what would be the problem wif my yoke. its stalls at road ends and somtimes between ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 27-06-2008, 21:59   #1
phiggman's Avatar
Default stalling felicia pickup
anybody any ideas on what would be the problem wif my yoke. its stalls at road ends and somtimes between gear shifts. could it be a fuel filter cos ther is no managment lights lit on control panel???????????
phiggman is offline
Old 27-06-2008, 23:24   #2
Friskodian
Captain Sisko's Avatar
Default Re: stalling felicia pickup
Stalls? for no apparant reason?
What engine is in your pick up?
98 Felicia 1.6 GLXI 109000 miles
Captain Sisko is offline
Old 27-06-2008, 23:59   #3
anewman's Avatar
I believe a good place to start would be to clean the throttle body with carb cleaner.
94 Favorit GLXIe Estate
anewman is offline
The Following User Says Thank You to anewman For This Useful Post:
phiggman (01-07-2008)
Old 28-06-2008, 12:44   #4
phiggman's Avatar
thanks guys and yes captain sisko it just drops the revs as i clutch to stop at road ends etc. its a 1.6mpi .just checked that inch pipe from the air intake area and its clogged although i dont see an easy way of removing the bottom end to cleanit. what is the best way to clean the tb? does any one want to have a guess at how much i paid 4 her u wont believe at
phiggman is offline
Old 28-06-2008, 22:24   #5
rigsby's Avatar
£10
I DONT WANT TO DIE A GROWN UP!!!
rigsby is offline
Old 30-06-2008, 11:54   #6
KenONeill's Avatar
Price - "take it away mate!!"?
Does it only die on you when the engine's cold?
KenONeill is offline
Old 30-06-2008, 19:04   #7
phiggman's Avatar
dies no matter what the temp is at.doesnt seem to have been very well serviced as its done this since i got it. just used carb cleaner and cleaned out that air pipe that sits inbehind the main air pipe and then took battery off to reset the throttle bodies as one of the threads explained. 190 quid actually i thought it was a bargain 4 a van [its got the fibre glass cube back on it see] that only needed a hand brake cable and a brke pipe 4 the test.
phiggman is offline
Old 30-06-2008, 22:14   #8
rigsby's Avatar
Bargain!!
rigsby is offline
Old 30-06-2008, 22:15   #9
phiggman's Avatar
just tried it buddy no joy the tick over is very low and it still stalls. would it be as simple as adjusting a tick over screw or does such a thing exist on these yokes???
phiggman is offline
Old 01-07-2008, 23:37   #10
phiggman's Avatar
RESULT!!!!!!!!! ONLY FOLLOWED BOTTLE INSTRUCTIONS TO CLEAN TB'S. THIS TIME THO I MANUALLY CLEANED THE THROTTLE BODIES WIH A TOOTH BRUSH DIPPED IN CARB CLEANER TILL IT WAS SHINING. TIGHTENED THE SLACK IN THE THROTTLE CABLE AND NOW SHES TICKIN OVER LIKE A MOUSE CHEWIN PAPER.[THINK IT WAS THE TB CLEAN THAT MADE THE DIFFERENCE.
CHEERS NEWMAN BUDDY 4 THE TIP.
phiggman is offline
The Following User Says Thank You to phiggman For This Useful Post:
anewman (01-07-2008)
