Steering clunk at low speed
This is a discussion on Steering clunk at low speed within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; My Felicia GLXi (which has power steering if you are not someone who has memorised all of the model names ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 11-07-2008, 17:41   #1
Question Steering clunk at low speed
My Felicia GLXi (which has power steering if you are not someone who has memorised all of the model names and their features) is making a clunking sound when the steering wheel is turned one half turn in either direction when stationary or travelling at low speed.
The sound appears to be coming from the middle of the engine, rather than one side. The sound does not get worse when the car has been in use for a while, nor does it get worse if the car has been travelling on the motorway.
I have looked at the tracking rod and end on one side, which were fine with no looseness or wear to the bearings. I suppose I should check the other side!
Any other ideas?
lopas is offline
Old 11-07-2008, 19:42   #2
rigsby's Avatar
Default Re: Steering clunk at low speed
Sounds like the steering rack mounting points loose
I DONT WANT TO DIE A GROWN UP!!!
rigsby is offline
Old 13-07-2008, 22:24   #3
Thank you for that Rigsby. You wouldn't happen to know which page of the Haynes manual might refer to that would you? I have read section 10 'Suspension and steering', but I can't seem to find anything about the steering rack mounting point.
Thanks!
lopas is offline
Old 13-07-2008, 22:31   #4
anewman's Avatar
The haynes will probably call it a "steering gear".
94 Favorit GLXIe Estate
anewman is offline
Old 14-07-2008, 13:11   #5
KenONeill's Avatar
I'd try "Steering column, removing and replacing".
KenONeill is offline
Old 14-07-2008, 17:40   #6
not a bird!!!
pinkskud's Avatar
can you feel the steering move when it knocks? if you cant then its probly not the rack moving
also found on
http://skodafelicia.freeforums.org/index.php
pinkskud is offline
Old 21-07-2008, 16:50   #7
No, I cannot feel the steering move when it knocks. I shall be attempting to have a look underneith this afternoon and will post with any further info.
Thanks
lopas is offline
Old 21-07-2008, 17:25   #8
not a bird!!!
pinkskud's Avatar
mine has the same problem (i think), it's worst when turning right, and evan worse when wet?????
i have had the engine rear stab mount changed and two new driveshafts, but this has'nt cured it.
also found on
pinkskud is offline
Old 21-07-2008, 19:14   #9
anewman's Avatar
If it's manual steering you'll be able to see the rack from above secured by 4 bolts. Try grabbing between this and see if it is fully secured. Also check the track rods, particularly the ends, for any play.
anewman is offline
Old 21-07-2008, 22:48   #10
not a bird!!!
pinkskud's Avatar
mine only realy knocks when under preasure. i think the rod ends will be my next port of call
also found on
pinkskud is offline
Old 22-07-2008, 09:40   #11
I propped up the front end and was unable to generate a clunk with the wheels off the ground. Attempting to rattle the wheels also revealed no play.
I have a new track rod end on the nearside, replaced last year.
lopas is offline
Old 23-07-2008, 23:40   #12
not a bird!!!
pinkskud's Avatar
ok, took mine to the vet's today, and we have sussed it.
i have f***ed the rack basicaly! when the cars up on the 4 point lift, you can grab hold of the wheel and give it a proper wrenching from side to side. its not enough to generate a clunck, but with the gaiter of that end of the rack, we could see an amount of play.
it don't seam like much, but remember a power steering has a silly amount of hydrolic pressure in it when operating, more so than you could ever generate by hand.
as a new rack is about £400, i'll be having a look on ebay soonish.
also found on
pinkskud is offline
Old 23-07-2008, 23:59   #13
anewman's Avatar
Try asking Graham at Jorily Skoda if he has any in Skoda Parts - Jorily. The Skoda Parts Shop - Probably the UKs largest independent skoda parts supplier Seems he's away at the moment but he got me a favorit manual rack for £100 brand new and dealers were asking £200 (and eager to point out they had one in stock). Although when this sort of thing does come up on ebay it usually is cheap. After I spent £100 on the rack a recon one turned up on ebay starting price £4 and someone on here won it for £4. Gutted, lol.
anewman is offline
Tags
clunk , felicia , low , speed , steering
