This is a discussion on Stone in a box?????? within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; When setting off in my n plate 1.3GLXi with 51500 genuine miles I am starting to hear a noise like ...
| Local Person Join Date: Jul 2006 Location: Wakefield
| Stone in a box?????? When setting off in my n plate 1.3GLXi with 51500 genuine miles I am starting to hear a noise like a stone in a metal box Only happens when pressing throtle Not too hard honest Also a squel when realy setting of quick well as fast as a 1.3 will go with a 24 stone bloke driving it
__________________ MY Rides N plate Felicia 1.3GLXi White 62196 miles07 plate DAF 105XF 410bhp(Standard Euro 5 ) Red 207698 kms |
| Re: Stone in a box?????? it might be the gear linkage rattling |
| The Following User Says Thank You to TeflonTom For This Useful Post: | scania666 (19-06-2007) |
| Briskodian Join Date: Jun 2007 Location: Brighton
| Re: Stone in a box?????? Another possibility is the exhaust - this could make that noise in two ways - either through knocking against something or through a loose baffle (or catalyst) rattling. If the noise is worse accelerating round corners then it is probably your cv joints hope this helps |
| The Following User Says Thank You to M4tthew For This Useful Post: | scania666 (20-06-2007) |
| Re: Stone in a box?????? Could it be your car screaming for mercy and looking for an 8 stone driver?? (I know coz my fabia does the same with me )
__________________ ![]() |
| Briskodian Join Date: Jul 2006 Location: Glasgow
| Re: Stone in a box?????? gear linkages!try holding the gearstick when puling away-noise should stop Happend on woody a week after we got him.. All that using 2nd as a brake from 45mph slackens it a touch... |
| | #6 | |
| Re: Stone in a box?????? Quote:
__________________ MY Rides N plate Felicia 1.3GLXi White 62196 miles07 plate DAF 105XF 410bhp(Standard Euro 5 ) Red 207698 kms | |
| | #7 | |
| Re: Stone in a box?????? If you can get access to a lift (or borrow a trolley jack, but a proper lift means walking rather than wriggling on your back under the car) get under and tap the silencer boxes. If they make a tinny rattle, it's baffles for sure. |
| The Following User Says Thank You to KenONeill For This Useful Post: | scania666 (20-06-2007) |
| | #9 | |
| Briskodian Join Date: Mar 2007
My 1.3 is reluctant to go back into second above 20 mph, attempts to encourage it result in a metallic grating noise from the box that im in no hurry to hear again ! | |
| | #10 |
| Re: Stone in a box?????? |
| | #11 | |
yeah no problem! sometimes complains if selected in a "spirited manner" but still does itAs Ken says, possibly worn synchros | |
| | #12 |
| Re: Stone in a box?????? I know it's clutch drag, worn synchros, or weak and hence beaten synchros. If some can do it, the weak synchros are ruled out, because that's a design issue, not a usage one. |
| | #13 |
| ECUless Join Date: Mar 2005
| Re: Stone in a box?????? The squeal is more than likely dust within the clutch, the rattle could be the rear brake compensator. |
| The Following User Says Thank You to fordfan For This Useful Post: | scania666 (21-06-2007) |
| | #14 |
| Re: Stone in a box?????? I think it was the baffles as yesterday sat in works car park and reved while stationary, the noise was there, it has however now gone
| | #15 |
| Re: Stone in a box?????? That's possible, if the baffles have broken up enough to no longer rattle, and/or get blown down the exhaust pipe. |
| The Following User Says Thank You to KenONeill For This Useful Post: | scania666 (21-06-2007) |
| | #16 |
| Re: Stone in a box?????? If the noise returns then you can check if it is baffles by using a screwdriver as a (rather basic) stethoscope. If you cannot get it on a ramp just pop one side on the curb and wriggle underneath on your back. Get someone to start and rev while you press the blade end against the exhaust and the handle end against your ear (careful, it gets hot fast!) you will be able to identify if and where the rattle is in the exhaust in no time. I know it sounds like hard work but it really is quick and easy - use an old jacket though. the screwdriver stethoscope trick works every time for identifying localised noises - from the exhaust to the tappets - you can even work out which tappet is loose this way! |
| The Following User Says Thank You to M4tthew For This Useful Post: | scania666 (22-06-2007) |
