This is a discussion on Upgrading Felicia Brakes within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; Hi Briskodians, I've been thinking for a while of a way to upgrade the front brakes on my felly by ...
| Briskodian Join Date: Jun 2008
| Hi Briskodians, I've been thinking for a while of a way to upgrade the front brakes on my felly by replacing the standard parts with ones from VW model range. What parts to go for that are a direct replacement?
__________________ marine Blue 97 skoda 138K and still going strong |
| Briskodian Join Date: Jan 2004 Location: DONCASTER
| Dunno about other vw parts, but i would go for a set of drilled and grooved discs and a good set of pads
__________________ I DONT WANT TO DIE A GROWN UP!!! |
| Briskodian Join Date: May 2006 Location: Hayling Island, Hampshire
| there isn't anything in the vw model range that will fit, so it will be custom jobbies i'm afraid ![]() ![]() i've got wilwood 4 pot calipers on corrado g60 280mm discs
__________________ |
| Briskodian Join Date: Feb 2008 Location: cleveland
| that looks like a after market adapter plate that the calipers are sat on did you get this custom made?
__________________ with out dissapointment you cant appreciate victory! |
| | #5 | |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Quote:
__________________ MK2 Golf GTi - APX 225bhp 1.8T - Emerald K3 - Quaife ATB - VR6 Widetrack - VR6 brakes front and rear - Neuspeed ARBs - Speedline alloys - H+R coilovers - Powerflex bushes - Helix clutch G60 flywheel - Adjustable solid top mounts - Custom engine bay - Tornado Motorsport MSA cage - and lots lots more. | |
| haha sorry didnt read it properly, have you got the plans handy that you used to get them made? + how much did they cost you ?
| hmmm, let me just fire up photobucket to see if i can find it
| ![]() you need to make up a ring to go on as well because the centre spigot for the brake disc is a smaller size (62mm) on the skoda hub as apposed to 65mm on vw hubs
| ![]() autocad drawing that i produced for them, on the right hand side there is a dimension marked 39, if you reduce this to 26 and adjust the rest accordingly it will fit the 256mm disc instead of 280mm ![]() finished bracket at a cost of approx £150 for the pair
__________________ Last edited by TeflonTom; 14-07-2008 at 00:32. |
| | #10 |
| ![]() 'ring' fitted to the hub if you want a set made, i'm pretty certain they will still have the CNC cutter paths stored on disc somewhere, i had them done at a local precision engineering firm riddiford racing and engineering they specialize mainly in making parts for speedyway bikes but they will do anything really
| | #11 |
| thanks for the clarifications and the nice illustrations. I need to enhance the braking power on my felly. Can i achieve this if i replace the rear drums with discs and pads? What to go for?
| | #12 |
| it is possible to fit rear discs using the stub axles and brake calipers from a lupo or 6n2 polo, but it would need a fair bit of fiddling around to make it work right, not to mention longer hand brake cables
