wheel bearing/hot tyre
This is a discussion on wheel bearing/hot tyre within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; hi everyone, first post here. hope you can help, '98 1.9 diesel felicia. front off/side tyre wearing very fast on ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 05-07-2008, 21:41   #1
Default wheel bearing/hot tyre
hi everyone, first post here. hope you can help, '98 1.9 diesel felicia. front off/side tyre wearing very fast on the inside and hot to the touch, the wheel is also hot. renewed both front wheel bearings, new off/s front tyre and the tracking checked. tracking out but has been adjusted. now the tyre is still hot on the top off the inside wall but the wheel/hub seems normal. why is the tyre still hot? any ideas thanks
adocs is offline
Old 05-07-2008, 21:54   #2
Default Re: wheel bearing/hot tyre
is the break on that side binging on? this will cause it to get hot whilst driving
with out dissapointment you cant appreciate victory!
skodafelicia is offline
Old 05-07-2008, 22:13   #3
no, the braking is good and the wheel/hub is cold/normal. its just the inside top wall of the tyre thats hot after only a few miles driving
adocs is offline
Old 05-07-2008, 22:37   #4
and it ain't rubbing on anything either
adocs is offline
Old 05-07-2008, 22:41   #5
anewman's Avatar
I'd consider swapping the wheels over and see if the problem follows the wheel/tyre.
94 Favorit GLXIe Estate
anewman is offline
Old 05-07-2008, 22:47   #6
the old tyre went bald on the inside and i think this one will too, with the heat thats generaterated, have i spelled that right?
adocs is offline
Old 05-07-2008, 22:47   #7
phiggman's Avatar
u sure it aint rubbin? even on corners and over bumps? is shock goosed?
pickup van 1.6mpi £190 workhorse! earning her keep!!!
35+MPG
phiggman is offline
Old 05-07-2008, 23:04   #8
generatered? lol
adocs is offline
Old 05-07-2008, 23:07   #9
no funny sounds or noises. nice car to drive as my normal one is a 20 year old land rover
adocs is offline
Old 05-07-2008, 23:09   #10
just can't understand why the tyre is hot and nothing else on the wheel
adocs is offline
Old 05-07-2008, 23:13   #11
think its generated
Old 05-07-2008, 23:15   #12
thank you sk
adocs is offline
Old 06-07-2008, 01:18   #13
Briskodiodion
TeflonTom's Avatar
are the suspension bushings worn out???
vorsprung durch czechnik
TeflonTom is offline
Old 06-07-2008, 07:02   #14
ECUless
fordfan's Avatar
Lower spring cup on the shock absorber deformed and catching the tyre?
fordfan is offline
Old 06-07-2008, 08:36   #15
theres a 2" gap between the cup and tyre and it was renewed about 6 months ago. not sure about the bushes though, anyway of checking them. Off to RAF Waddington air show now so I won't be able to check any replies, thanks
adocs is offline
Old 06-07-2008, 09:54   #16
Friskodian
Captain Sisko's Avatar
My front left was wearing on the outer edge. Cant see it happening on the tyre thats currently on it, but the fronts need replacing now so will see if that problem was cured when the tracking and front shocks were changed.
98 Felicia 1.6 GLXI 110500 miles
Clickable for "boring" info
Captain Sisko is offline
Old 06-07-2008, 10:56   #17
JRHartley's Avatar
Could be the lower wishbone mounts. Not familiar with the Felicia but I had this problem with a Pug 306. The tracking was spot on but the tyre kept wearing badly on one edge. Turned out to be the wishbone pivot bushes that were shot but they only allowed play when the vehicle was moving forward. The play allowed the wishbone to splay outwards slightly when driving the car forwards but when the car was stationary the wishbones returned to their correct poisition and the tracking was back in line when ever it was checked.
JR
I'm a celebrity...... Get me out of here !!!
JRHartley is offline
Old 06-07-2008, 13:34   #18
Briskodiodion
TeflonTom's Avatar
that's exactly what i was thinking
Old 06-07-2008, 20:42   #19
thanks for the help, probably be the job for next weekend
adocs is offline
Old 07-07-2008, 12:50   #20
KenONeill's Avatar
That or the lower ball joint. I've seen that happen, and the (lady) driver only picked up that there even was a problem when the tyre was down to the re-enforcing belts.
KenONeill is offline
