40,620 Members 1,518,547 Posts
whirring noise when dipping the clutch
This is a discussion on whirring noise when dipping the clutch within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; hi all.......my r reg 1.3 mpi has a whirring whizzing noise when i dip the clutch pedal.....it goes away when ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 01-04-2008, 20:04   #1
Members Car:
hi all.......my r reg 1.3 mpi has a whirring whizzing noise when i dip the clutch pedal.....it goes away when i release it and it only happens when the engine is warm??????? i will be changing the transmission oil tommorow as the car has hit 40600 miles but this noise has me stumped......
IF ONLY I HAD A BRAIN
joekelly9692 is offline
Old 01-04-2008, 20:14   #2
Briskadoodian
swedishskoda's Avatar
Re: whirring noise when dipping the clutch
Worn clutch release bearing? Could give a whirring or even /whistling/squeaking sound? A bit early after only 40,000 miles but anything can happen. Has the clutch ever been changed?
It's feral ! It's fervid! It's a Felicia!
swedishskoda is offline
The Following User Says Thank You to swedishskoda For This Useful Post:
joekelly9692 (01-04-2008)
Old 01-04-2008, 21:42   #3
rigsby's Avatar
Simple solution -- dont press clutch lol
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
The Following User Says Thank You to rigsby For This Useful Post:
joekelly9692 (02-04-2008)
Old 01-04-2008, 23:50   #4
anewman's Avatar
Images: 1
Hurrah for powershifting
94 Favorit GLXIe Estate - brakes now sorted (I think) and back on the road
Briskoda "Banger" social group
anewman is offline
The Following User Says Thank You to anewman For This Useful Post:
Old 02-04-2008, 07:52   #5
Friskodian!!!
Captain Sisko's Avatar
I can change gear without using the clutch but cant get into first
How do you do that?
Gone = Skoda Felicia 1.6 GLXI 120k miles
Now Skoda Favorit 1.3 LXI 50k miles
Clickable for "boring" info
Captain Sisko is offline
The Following User Says Thank You to Captain Sisko For This Useful Post:
Old 02-04-2008, 12:32   #6
KenONeill's Avatar
Members Car: Octavia TDi110
For the OP and Swedish, it's early for a clutch release bearing problem, unless the car's done lots of town mileage in the hands of someone who sat at lights with the clutch down, and that seems quite likely with a 10YO car that's only done 40_000 miles.
For Cptn S, it's tricky when stationary, and not usually necessary when rolling. If it is necessary, remember that the change into first is usually the slowest on any car.
KenONeill is online now
The Following User Says Thank You to KenONeill For This Useful Post:
Old 02-04-2008, 12:32   #7
WoodieGuthrie's Avatar
Members Car: Totally Stock:-)
Sounds like a thrust bearing issue- should still shift ok, but noise may get worse.
it'll be a gearbox off job to change, may as well do clutch whilst its off-2 birds, 1 stone
WoodieGuthrie is offline
The Following User Says Thank You to WoodieGuthrie For This Useful Post:
Old 02-04-2008, 12:52   #8
Briskadoodian
Agree, it would be surprisingly early. I always sit with clutch down at lights and sold my old Micra with 200,000 miles on the clock (not all of them town miles of course) with original bearing and clutch working perfectly.
But sometimes things do break down long before estimated time.
When/how does the noise appear? As soon as you press the pedal? When pedal is at the floor? Ore somewhere in between?
Old 02-04-2008, 15:31   #9
Members Car:
thanks for the replys everyone.....the sound only happens when the clutch is all the way down.....and only happens when the engine is at full operating temp.....the gear shif tis very smooth.......i bought the car from a dealer so im not sure how old the clutch system is......from the service history it seems like its been well serviced and had one lady owner.....hope this one is not expensive.....thanks guys and ladies
Old 02-04-2008, 16:00   #10
Briskadoodian
Probably not the bearing then as it should squeal as soon as it's under pressure. If there's a good mechanic close by, ask him to listen (or her ) - hard to diagnose on the web (I have seen postings here with audio files attached, though)
Wonder what would happen if you just slacked the clutch cable a tiny bit? Do you have to push the pedal all the way down to completely release the gearbox/engine? Is there a lot of play or practically none?
Old 02-04-2008, 17:36   #11
Members Car:
its a strange one..........the clutch and gear shift feel fine.........my old man......who was a taxi driver for around twenty years mentioned its somthing to do with the flywheel????? it must be really difficult to diagnose with a described sound.......it sounds like a passive noise.....not grindy or whiney just whirry lol....also the thread about the clunking noise recently posted.....my car has this symptom.....maybe connected....hmmmmm
Old 03-04-2008, 08:30   #12
KenONeill's Avatar
I didn't think Felicias had dual mass flywheels? Of course, the clutch release bearing presses on the flywheel.
Similar Threads
Clutch noise Sikaniska Favorit, Felicia, Fun and Forman 9 29-03-2007 09:23
Noise when dipping clutch in 3rd gear... maffwilson Fabia I 2 27-12-2006 00:01
Whirring Noise when opening drivers door Eoin Riddell Octavia I 4 10-02-2006 23:41
Whirring noise Skodacious Octavia I 21 18-10-2004 15:51
Clutch noise day tripper Maintenance & Performance 1 16-09-2004 20:39
