39,348 Members 1,485,715 Posts
wouldnt start then odd behaviour
This is a discussion on wouldnt start then odd behaviour within the Favorit, Felicia, Fun and Forman forums, part of the Skoda Model Discussion Area category; ok so i have to be at the hospital at 8.45AM its 8.40AM and the car won't start. - took ...
Go Back   BRISKODA - The Skoda Forums > Skoda Model Discussion Area > Favorit, Felicia, Fun and Forman
Old 01-12-2007, 00:49   #1
Felicia racer's Avatar
and the car won't start. - took Mbike instead.
anyway,
I used jump leads from my mums car with its engine off to my felly.
I dissabled the immobiliser then started to crank the motor over, It did'nt want to start. untill i pressed the throttle. (I dont normally have to do that)
then it fired into life. and revved to 2000rpm as a tickover speed!
eventually after removing the leads and waiting a few mins the revvs dropped bacxk to normal. So i used my spare key and locked the car whilst running the engine to charge the battery.
every few seconds it would rev on its own to about 1750rpm and drop down to tickover again.
Any ideas? - (ocassionally it dies just after starting, but it hasnt done that in ages.)
Laurin & Klement
1.6 mpi Felicia estate
Towbar parking sensors are brilliant
PLEASE VISIT MY FORUM http://hondacb400.myfreeforum.org/index.php
Felicia racer is offline
Old 01-12-2007, 14:41   #2
Psyzygy's Avatar
Location: Behind the wheel of a small automobile somewhere in the East Midlands
Re: wouldnt start then odd behaviour
Was the battery dead when you came to it this morning or did you flatten it trying to start the car?
The occasional rise in revs sounds like what was called "hunting" on carburated motors & is a sign of a too rich tickover mixture. I'd suspect something like the idle switch or throttle valve sensor in the Throttle body...
What's it like under load? Have you driven it round the block yet?
Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt )
Psyzygy is offline
Old 03-12-2007, 21:36   #3
richardsfavorit's Avatar
My sisters did some strange things a while back - it had me puzzled. The temp sensor didn't work but I thought it was unrelated.
Sometimes it wouldn't start without giving it some throttle - and then when it did start it sort of chugged! It would also idle at 2000 / 2500rpm. I took it to our garage, and he rigged it up to VAG COM, and the temp sensor thought the engine temp was 35 degrees when it was boiling hot! So when cold it thought it was about -50! We put in a new temperature sensor, problem solved.
richardsfavorit is offline
Old 03-12-2007, 23:28   #4
thanks for the reply's
yes the battery was dead when i got there, It only had enough power to unlock the central locking and alarm and imobiliser! - even then it did it slowly/ struggled.
I took it out for a drive saturday and friday night, It seemed like normal and started fine. I did'nt use it on sunday.
I came to use it tonight and there was no power again.
The battery is a good make, and was only fitted last year.
anyone think of any other problems?
anyone is kent got VAG-COM?
Laurin & Klement
Old 03-12-2007, 23:42   #5
not a bird!!!
pinkskud's Avatar
Members Car: 1.6l felicia 1998
mine does this, not the dead battery thing. but the rest sounds very familiar behavior for my 1.6
i had put it down to dodge throttle body, but looks like i may be wrong.
also found on
http://skodafelicia.freeforums.org/index.php
pinkskud is offline
Old 03-12-2007, 23:54   #6
ocasionally the car would start then die straight away.
people have indicated this could be a problem with the throttle body.
what is it and where is it and what does it look like?
I've been told it needs cleaning.
any idea's on what could be causing the dead battery?
Laurin & Klement
Old 04-12-2007, 00:02   #7
not a bird!!!
pinkskud's Avatar
take the plastic cover off the engine.
the air intake is plummed right into the top of the throttle body, you'll know your there when you see the butterfly valve.
also found on
pinkskud is offline
Old 04-12-2007, 00:05   #8
don't want to sound cheeky anyone got any pic's
do you know how to clean it and what bit to clean edd?
Laurin & Klement
Old 04-12-2007, 00:13   #9
Members Car:
i can put some pics from the haynes manual on here would i be allowed or are they copyrighed images?
jeffers is offline
Old 04-12-2007, 00:20   #10
omg i never thought of that i have a haynes 4 de car!
Laurin & Klement
Old 04-12-2007, 00:25   #11
Members Car:
im looking at it now, doesnt tell you how to clean it and i dont knowto be honest but i is quite clear on what to do to get at it
page 4b.4 if your wondering
jeffers is offline
Old 04-12-2007, 09:52   #12
Psyzygy's Avatar
Get a tin of carburettor cleaner from your local car accessory shop and do what it says on the tin
(And don't be offended Haynes? NUMPTY )
Psyzygy is offline
Old 04-12-2007, 18:51   #13
not a bird!!!
pinkskud's Avatar
get some carb cleaner. and make shiny all the bits that are black inside.
also found on
pinkskud is offline
Old 04-12-2007, 19:04   #14
Jaymz's Avatar
Members Car: Skoda Felicia GLXI
mines doin tht sorta thing well did think it may have just been reli cold or battery on way out
Pooky Power!!
Jaymz is offline
Old 04-12-2007, 23:04   #15
rigsby's Avatar
My fun did the same after i left my amp switched on all night, but righted itself after a good charge. if it continues playing up after getting battery sorted try disconecting both battery terminals and joining the cables together for 30 seconds, this ( if like a lot of vehicles)might reset the ecu
If your batetry keeps going flat check that the boot light is going off when the boot is closed. it took me a couple of days of jump starts to find this on our lasses felly
I DONT WANT TO DIE A GROWN UP!
rigsby is offline
Old 05-12-2007, 17:59   #16
my bootlightt has a switch on it,
but will only come on with the sidelights on!
anyone elses do that?
Laurin & Klement
Similar Threads
Odd noise on start up? robert_waite Fabia I 3 14-08-2007 09:26
odd behaviour scraggman Octavia II 4 28-03-2007 21:55
weird cold start behaviour noodles Octavia I 11 11-11-2005 15:59
Felicia Lxi: 96: 1300 Won't start. Will start. laflaff Favorit, Felicia, Fun and Forman 1 04-05-2005 23:18
disturbing behaviour tonylegg Off Topic and Chit Chat 2 05-12-2003 23:15
