This is a discussion on 007P Recirc Valve within the Forge Motorsport forums, part of the BRISKODA Partners category; Sorry for yet another question, I seem to be bombarding you with them recently. I believe my 007P DV may ...
| Briskodian Join Date: Jan 2005 Location: Aylesbury, Bucks
Members Car: '51 Octy VRS Thanks: 4
| 007P Recirc Valve Sorry for yet another question, I seem to be bombarding you with them recently. I believe my 007P DV may not be working properly, and opening too soon. Its got the correct spring, but I was just wondering if you offering a service facility on valves, and how much it would be? Thanks Andy
__________________ Rally Red Octavia vRS - 19" RS4 reps - KW v3 - Blueflame Turbo back exhaust - Forge TIP - Forge 007P - Carbonio- Milotec WRC spoiler - debadged grille - Autometer boost gauge To be done - Whiteline front & rear ARB - new alloys - FMIC - dogbone mount - oh, and a remap |
| Site Sponsor | Re: 007P Recirc Valve We would normally inspect the valve every 12,000-20,000 miles . In order to determine if the valve requires a service I would recommend that you carry out the "leak back test" , in order to see if it is required. 1. Simply push/displace the bottom piston up to the top of the valve either using your finger, a pen or any suitable implement, whilst doing this cover the top small vacuum nipple with your index finger. 2. Leaving your finger covering the vac nipple, remove the pen, the piston may drop approx 5mm but should then stay in position by vacuum. 3. You should now see through the bottom port that the piston is held/drawn to the top of the valve . 4. Next, remove your finger from the vac nipple. The piston should return to its seat. 5. Repeat this test several times and if there is no gradual leak back all is satisfactory and the valve can be refitted to your vehicle. 6. If however the piston moves back down, whilst you have your finger covering the vacuum nipple, the valve requires servicing. If this is the case please contact us again
__________________ |
| NOW @ PEUGEOT Join Date: Nov 2003 Location: Bicester,Oxfordshire
Members Car: 2 x octavia vrs 03&01 Thanks: 32
| Re: 007P Recirc Valve Andy, if you get stuck/lost doing this pop it down to me Saturday if your about with or without the car and i can check it for you Service mine regular so getting good at itPhil
__________________ 1)RED ONE, FEW MODS; AND A HEALTHY 237bhp 2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT ![]() LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE |
| Re: 007P Recirc Valve To the Forge lads and ladies, thanks, will try that tomorrow Phil - thanks for the offer, unfortunately I've only just seen your reply now!!
| Re: 007P Recirc Valve Thanks again to Forge! Got the service kit and all fitted!! Brilliant service!!
| Site Sponsor | Re: 007P Recirc Valve Glad all is well
| Reversal of 007p Valve | mluton | Forge Motorsport | 20 | 11-09-2007 07:59 |
| DV30 Recirc Valve | damo :-) | Maintenance & Performance | 4 | 06-08-2006 17:31 |
| recirc valve | blackmeragti | Octavia I | 4 | 19-03-2006 16:20 |
