Turbo Dynamics turbos
This is a discussion on Turbo Dynamics turbos within the Formula One forums, part of the BRISKODA Partners category; Ok peeps as promised here are our deals on the turbo dynamics turbo's for the fabia'a and octavia's. First up ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Formula One
Old 19-10-2007, 15:30   #1
Site Sponsor
Default Turbo Dynamics turbos
First up the fabia vrs
Stage 1 – MD374
Hi flow GT17 compressor wheel, cnc machined compressor housing, 360 degree thrust
bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’,
modified V.N.T. turbine housing, uprated turbine seals. Other ‘blueprinting’
modifications. APPROX 200 - 220 BHP
Our price is £975inc
Stage 2 – MD376
Hi flow GT20 spec compressor wheel, cnc machined compressor housing, 360 degree
thrust bearing, cut back turbine blades, lightening of turbine wheel for faster ‘spool up’,
modifications. APPROX 220-240 BHP
Our price £1030inc
If you woule like us to fit them along with other tuning parts that are needed to get the best from this set-up then please p.m me and i will quote for nozzles,intake's,fmic,de-cats and software etc........
Octavia vrs....
Stage 1 MD349
High flow K04 2275 Spec Compressor wheel, C.N.C. re-profiled compressor
housing, 360 degree thrust bearing, modified watercooled bearing housing, cut
back turbine blades, lightening of turbine wheel for faster ‘spool up’, modified
turbine housing, up-rated twin turbine seals. Other ‘blueprinting’ modifications.
APPROX 260-280 BHP Maximum recommended boost level – 18-20 P.S.I.
Our price £975inc
Stage 2 MD445
K04 turbo with Hi flow K04 compressor wheel, cnc machined compressor
housing , large trim K04 turbine wheel, lightening of turbine wheel for faster
‘spool up’, cnc modified turbine housing, ported wastegate, uprated turbine seals.
Other ‘blueprinting’ modifications. 12 psi Uprated actuator APPROX 280- 300
BHP. Maximum recommended boost level – 24-26 P.S.I.
Our price £1260inc
Again if you would like us to spec the car to produce the quoted power figures then please p.m me....
If there is enough interest in the turbo's say at least 5 buyers then a further 5% discount will apply..............................
ta tar...................................
f1btn is offline
Old 19-10-2007, 18:30   #2
mr. hedgehog's Avatar
Default Re: turbo dynamics turbo's
I'm guessing the second turbo is a bit overkill if you don't have uprated injectors?
Just out of interest, what sort of package (£) could you do for turbo, fitted + mapping?
Fabia VRS - Heated full leather, cruise, 160 intake, green filter, Forge FMIC, CC Stage 1, 312mm drilled Zimmermans, Momo Strutbrace, Jabba ARB, Eibach springs, Octy 17"s & Cupra R splitter, Helix Clutch & SMFW. Allard EGR bypass. Bring on the VT2...
mr. hedgehog is offline
Old 19-10-2007, 18:34   #3
One other Q? If I go in on the group buy, I wont be having the turbo fitted until after xmas, Probably in Feb or March with my next service. Considering this, would the start date for the warrenty be from purchase or fitting?
Old 20-10-2007, 10:13   #4
Site Sponsor
The warrenty will start when you puchase the turbo not when its fitted! These turbo's however are fairly bulletproof if looked after properly. Its essential however that you allow the turbo to just tickover for 10mins or more before driving it when first fitted, if you then give the turbo an easy time for the first 100 or so miles (not essential but its what i do) then it will be fine im sure,also allow the turbo to spool down for a few minutes after a spirited drive etc.
Im dont think the turbo's come with new oil lines, so if fitting it yourself make sure that these are in good condition.....
Thanks
f1btn is offline
Old 20-10-2007, 10:13   #5
Site Sponsor
Oh and you have a p.m.............
f1btn is offline
Old 20-10-2007, 10:15   #6
Mongreller
devonutopia's Avatar
No, it's not. They're fine to reach the quoted 240bhp, with other mods - you only need the injectors sorting out if you're going for the high 200s.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 22-10-2007, 23:47   #7
wot about over 300 jase?
Gary
www.dogboxmedia.co.uk
oilburninnut is offline
The Following User Says Thank You to oilburninnut For This Useful Post:
devonutopia (23-10-2007)
Old 23-10-2007, 00:10   #8
Mongreller
Whoops, hit thanks first before quote.
I imagine the TD2 will go close to 300, but it will need modded injectors and a few other mods to get there I believe. Injectors are the key weak link as they flow 550ccm as stock, and you need around 700 to get past 300bhp (apparently, so I was told)
Old 23-10-2007, 20:25   #9
would you need to uprate the fuel pump?
Gary
Old 23-10-2007, 20:29   #10
Mongreller
The injectors work like 4 individual fuel pumps. They will need uprating to get up past where I am now.
Old 23-10-2007, 20:53   #11
thats what i meant,have you seen my dyno sheet from awesome on saturday,it makes interesting reading,its in the n/west meets section,
Back on topic got a quote from jbs for a turbo conversion 240bhp over 3k,does include injectors and labour,is this what i should be expecting?
Gary
Old 23-10-2007, 20:59   #12
Mongreller
Possibly. But I would do more. Full decatted exhaust system and FMIC would be fairly essential as well. This thing goes on and on mate
Old 23-10-2007, 21:18   #13
Still a ****
delcac's Avatar
....and on.
Can we get back to the add by F1, perhaps direct your questions at F1 as this is their forum after all.
The Red Devil
delcac is offline
Old 23-10-2007, 21:38   #14
Briskoda Staff
VRStu's Avatar
Guys - Please be mindful that this is a partner thread and not Allard discussion.
Stu - Freedom Pimp
Stu's Car - Hmm, Have a guess......
VRStu is offline
Old 23-10-2007, 21:57   #15
Mongreller
I never mentioned the "A" word once, but I agree this thread needs cleaning up. I imagine F1 would be able to sort Gary out with all the tuning bits I mentioned anyway. They seem pretty clued up on VAG diesels from what I've seen.
Old 23-10-2007, 22:14   #16
Still a ****
delcac's Avatar
Shhhhh!
Post 8.
The Red Devil
delcac is offline
Old 23-10-2007, 22:19   #17
Mongreller
grey cells... fading.
Old 03-11-2007, 08:02   #18
Hardcore
Basil's Avatar
Good prices. I have the stage 2 hybrid MD376.
The thing seems to work effortlessly compared to the OEM one - able to run 2 BAR all day long if desired...
Chose it as I wanted minimal turbo lag and max torque throughout the rev range. The combo of OEM size impeller and uprated compressor just made perfect sense to me... Direct bolt-on, no messing about with a bespoke exhaust manifold nor chance of potentially more turbo lag with the VNT20 series....
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 03-11-2007, 09:10   #19
Site Sponsor
Thankyou for the feedback,ive always trusted td and they have made a number of bespoke turbo's for me over the years! Not many people know that they make the control turbo's for the leon cupra cup cars either.....
f1btn is offline
Old 03-11-2007, 16:21   #20
whats the all in price of a turbo,injectors and all i would need to carry out a swap,i am looking for max power btwis there anymore to be had for 300+bhp?
Gary
