This is a discussion on 1.4 rattle within the Fabia I forums, part of the Skoda Model Discussion Area category; I have a rattle at idle speed on my 1.4 8valve (eng type AQW) fabia comfort have removed the aux ...
| Briskodian | I have a rattle at idle speed on my 1.4 8valve (eng type AQW) fabia comfort have removed the aux drive belt to stop the air con, alternator etc but rattle continues,. sounds like camchain is lashing about drives ok but intermittent stalling no lights on ,car has 50.000 miles on it first reg01 I dont think there are many of these 8v-fabias about does anyone know the camchain set up regarding the tensioner ,spring or hydraulic has anyone heard of this problem on an 8 valve before. |
| Yep cam chain normally gets a bit rattly as they get on a bit. And believe it or not there isnt a tensioner. |
| Briskodian | Thanks for the info in that case is the only fix a new chain? is it a big job, can it be done with engine in . Have to fix as noise is bad have been asked if it was a diesel by cheeky bloke. |
| | #4 | |
| Briskodian Join Date: May 2005 Location: Planet Earth
Members Car: Octavia II 1.9TDI DSG Elegance Estate Thanks: 8
| Quote:
__________________ Skoda Octava II Estate 1.9DSG Elegance Anthracite Grey Skoda Fabia 3 1.6 Tiptronic Storm Blue | |
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| I believe all 8 valve models have a rattle/shudder condition at idle speed. Can't remember why, I can't get technical, but an advisor at the dealership told me this...unless it's just for the 2.0 he was talkin about.
__________________ Milton Kyvernitis Private Government |
| Briskodian Join Date: Jul 2004
Members Car: skoda fabia AME 1.4MPI Thanks: 0
| Mine rattled like crazy after just 25.000km. I've changed the timing chain arround 39.000km and now I have 47.000km and it's very quiet. The problem is that theese engines have no timing chain tensioner. I believe good full synthetic oil can help to enlarge the period until the engine will rattle again. Unfortunately there is no cure but the chain replacement. A loose chain inserts small delays in the timing of the engine and thus it slightly reduces performance. |
| Fabia comparison. 1.4 16v vs. 1.9 TDi | Tom_vRS | Fabia I | 28 | 12-06-2005 18:56 |
| 1.4 Tdi advice | papadakisn | Fabia I | 6 | 04-05-2005 09:27 |
| Powerbox on 1.4 TDi | Smiorgian | Maintenance & Performance | 12 | 07-02-2005 14:40 |
| Octavia Rear Rattle cured | Stuart_J | Maintenance & Performance | 1 | 12-05-2003 09:11 |
| Rattle, Rattle, Rattle, AAAAAAHHHHHHH! | funkyjutel | Maintenance & Performance | 3 | 28-11-2002 11:15 |
