This is a discussion on 2 quick questions (air con and leaky doors) within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi everyone Two quick questions for you: 1. With the air-con and re-circ buttons both on (lit), is the re-circ ...
| Briskodian Join Date: Jun 2007
| Hi everyone Two quick questions for you: 1. With the air-con and re-circ buttons both on (lit), is the re-circ light ever supposed to switch itself off automatically? Several times now, I put both the air-con and re-circ on together yet 10 minutes later I notice that the re-circ button has gone out (the air-con remains on). Is this normal behaviour or have I got a fault? 2. I apologise for the picture, but I have a leaking rear door! I have read the other posts and it SEEMS the problem is water leaking from the door inside. My question is, is the water leaking in through points C1 and C2 or all of them in my pic? If it's at C1 and C2, then (because only I use the car) I was thinking of putting some transparent sealant along C1 and C2. Good idea? Thanks! Fab vRS |
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
| Mine is coming in through the bottom of the door
__________________ '04 Fabia VRS - 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints |
| Briskodian Join Date: Jan 2005 Location: Manchester UK
| Yes, I know that the water comes out of the door at the bottom, but I'm trying to understand how it gets INTO the door in the first place. So a bit of transparent sealant at C1 and C2 would fix it? |
| Briskodian Join Date: Oct 2006 Location: Still in Suffolk
| 1. Thats normal. Not sure of the length of time through. 2. C1 and C2 I'd say (get confirmation first). Clear sealant would be a bit of a bodge, and will peel off and look awful. Your car, your rules ![]() HTH ![]() |
| Oh . . . So I'm f***ed then? |
| 1. The recirc light going off by itself isn't normal AFAIK, but is a sign of an electronic fault with the flap motor controller rather than with the motors themselves (in which case the light would go straight back out again). Resetting them with VAG-COM (or the dealer's diagnostic tool) ought to put that right. 2. Rainwater runs down the bottom of the window on EVERY car that has windows that open by retracting into the door. If it didn't, you wouldn't be able to open them! What's supposed to happen is that the ancillaries carrier inside the door is supposed to be sealed, so that as Sparky2 says, the water runs over the outside of the carrier and out through drain holes in the bottom of the door. However, in the case of the Fabia, the seal between the edge of the carrier and the door structure isn't very good, so some water goes the wrong side of the seal and leaks inside the car. The situation isn't helped by the fact that the drain holes are so close to the sill that the surface tension of the water prevents it all draining away properly, which is why you're greeted by a little trickle of water from the bottom of the door when you open it and break the surface tension... Not Skoda's finest hour, that's for sure...
__________________ |
| | #10 |
| | #11 |
| Hmm, okay! As well as resealing the doors, would it be worth drilling some holes into the bottom of the doors so that the water drains away faster? Or is that just a daft idea? |
| | #12 | |
| Quote:
Maybe it's me that's got it wrong, but it stays on as long as the car's running on mine and my wife's. Mind you, what with the reverse / recirc function, it may be that it turns off after you've finished reversing?
__________________ | |
| | #13 |
| Mine doesn't come on when I reverse, well at least the light doesn't ![]() |
| | #14 | |
| Quote:
In the meantime, old newspaper in the footwell is the best solution, as it'll soak the water out of the carpet, and you can just chuck it away once it's done its job!
| | #15 | |
| Quote:
) A sesh on VAG-COM should tell you more...
| | #16 |
| ok, thx everyone! |
| | #17 |
| | #18 | |
| Quote:
| | #19 |
| Damn your memory... ![]() I generally have it on 'one' so maybe thats why I haven't heard a change in noise either. |
| | #20 | |
| Quote:
* just kidding! *
| The Following User Says Thank You to ap0gee For This Useful Post: | *tim* (23-11-2007)
