39,396 Members 1,487,263 Posts
20k mile service - what needs doing?
This is a discussion on 20k mile service - what needs doing? within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi everyone, I've got the furby booked in tomorrow for a 20k mile service and just want to check whats ...
Old 11-01-2007, 22:00   #1
Irf
Irf's Avatar
Members Car: Furby vRS
Hi everyone,
I've got the furby booked in tomorrow for a 20k mile service and just want to check whats involved. A far as I am aware theres the oil, oil filter and air filter? It's not a Skoda dealer doing the service but they use Skoda parts so warranty isn't affected (apart from the mods lol).
Is it worth changing the cabin filter and fuel filter etc as these don't cost much? And should I ask the garage to check/change anything else?
FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter, 312mm brakes...
ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60....
NEXT: re-remap & clutch
Irf is offline
Old 11-01-2007, 22:01   #2
ScoobyChris's Avatar
Members Car: Fiat Panda
Re: 20k mile service - what needs doing?
Think the pollen/odour filter is done at 20k, but the air filter is done at 40k
Chris
ScoobyChris is offline
Old 11-01-2007, 22:30   #3
Members Car:
Oil + filter, pollen filter, drain fuel filter, check/top up gearbox oil.
As Chris says, air filter isnt done til 40k.I think it points all this out in the service book tbh.
DanSXE is offline
Old 11-01-2007, 22:44   #4
maxcars1's Avatar
Members Car: Seat Ibiza TDI MK4
fuel filter defo changed and not just drained, according to my Skoda Dealer Service Guide
100PD converted to 130 Spec Mods: To many too mention
maxcars1 is offline
Old 11-01-2007, 23:40   #5
Irf
Irf's Avatar
thanks for that guys, will dig out the service guide now, need it for tomorrow anyway
Irf is offline
Old 12-01-2007, 18:22   #6
Members Car:
Tick sheets at my place of work say:
10k = Oil + Filter change.
20k = As I mentioned above.
40k = Oil + Filter.Air and pollen filter and fuel filter change on diesels.Spark plugs on petrols.
Unless you're running bio-diesel, where it'll be 10k fuel filter drain, 20k fuel filter change.
DanSXE is offline
Old 12-01-2007, 19:42   #7
Members Car:
Just had mine done at 20k - oil change & new filter. Cost was just under £70. Brooklyns, Redditch.
setsquare is offline
Old 12-01-2007, 20:03   #8
Irf
Irf's Avatar
Well I got the car back today. Had the air filter cleaned (green cotton), oil + filter changed, waiting on a fuel filter as they couldn't get the correct one and they checked the gearbox oil and the other levels etc. They canged the cabin filter but the fan makes a weird noise whenit's on so i'll get them to check it next week. They also did the tracking (which isn't right as steering wheel isn't central so thats going back) and fixed the sensor for the xenons. Came to just over £250 which is a lot but they did spend a lot of time with the lights etc.
Irf is offline
Old 12-01-2007, 22:36   #9
Cupra Bush King
Lummox's Avatar
Images: 2
Fuel filter isnt required until 40k by the service schedule.
www.unit18.co.uk
Lummox is offline
Old 12-01-2007, 22:37   #10
Cupra Bush King
Lummox's Avatar
Images: 2
Should have had a pollen filter and tha is very cheap for an inspection service.
www.unit18.co.uk
Lummox is offline
Old 12-01-2007, 23:40   #11
tonystop's Avatar
Members Car: Mazda MX5 MK2.5
I know it’s late in the day but for the 20k service (2 year including inspection) is:
Oil, Oil filter, Filter pollen and brake fluid (every 2 years)
30k service is the oil and oil filter (as 10k)
40k service (4th year) is now the big one (bit of debate on here) but is the following:
Oil, oil filter, air filter (paper type), pollen filter, fuel filter, brake fluid (every 2 years) and finally the small task of replacing the cam belt, tensioners and water pump
Someone will be along to back this up or put me right, this is what I am believe to be so anyway.
I am dreading the 4th year service, or just I bite the bullet and have this as the excuse to trade up to the Octavia Vrs
tonystop is offline
Old 12-01-2007, 23:42   #12
tonystop's Avatar
This sounds like just a oil service to me and not an inspection service Just my humble option
tonystop is offline
Old 13-01-2007, 00:14   #13
Members Car:
Skoda advise the timing belt + tensioner should be changed at 4year intervals.Regardless of mileage covered, unless it's recommended mileage is done before the 4 years are up.
Example: We've done a timing belt on a 16v Fabia that was 5 years old and only covered 16,000 miles or so.
The water pump isn't strictly advised by Skoda (techies get told to check for play,weeping etc) but an owner can request the water pump to be changed with the belt + tensioner and I'm sure most garages will not add any additional labour time.
DanSXE is offline
