This is a discussion on Adjusting sweep of driver's wiper arm within the Fabia I forums, part of the Skoda Model Discussion Area category; Something that's been bugging me for a while, and fitting a new set of aero wipers at the weekend reminded ...
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Adjusting sweep of driver's wiper arm Something that's been bugging me for a while, and fitting a new set of aero wipers at the weekend reminded me... They're the Bosch retro-fit set, same as the ones from wiperblades.co.uk - but I find that every couple of wipes I can hear the blade catching the driver's pillar. Gets annoying when I had the wipers on full for most of yesterday afternoon! Incidentally, the Renault dealer sourced ones did the same. Thought this set might help, as the driver's side blade isn't as long, but no such luck... So - what's the best way I can sort this? Thanks, Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
Members Car: silver Fabia VRS Thanks: 31
| Re: Adjusting sweep of driver's wiper arm your going to have to move the arm round on the spindle Steve , it will be a pig to get off the spindle though, just don't move it too far round or it will hit the scuttle panel
__________________ not so bored now |
| Re: Adjusting sweep of driver's wiper arm Thought that might be the solution, as much as I didn't want it to be ![]() Fiddly, trying to get the adjustment between pillar and scuttle correct ![]() Do you think a slight bit of pressure on the arm would make any difference? It's a couple of mm adjustment, really. Cheers, Steve
| Moving Stables | Re: Adjusting sweep of driver's wiper arm Easy peasy to get the arm off steve. i used a pair of vise grips on mine and they popped straight off. Just need to pop the cap off first then get a 13mm socket and ratchet and your away
__________________ Run out of CASH |
| | #5 | |
Members Car: Audi S3 Thanks: 145
| Re: Adjusting sweep of driver's wiper arm Quote:
![]() To remove the arms I tend to remove the nut and then gently rock the base of the arm. If that fails and you get really stuck then a wiper arm removal tool can be bought quite cheaply.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio | |
| The Following User Says Thank You to VRStu For This Useful Post: | Wardy (20-11-2007) |
| Re: Adjusting sweep of driver's wiper arm the problem you will have is when you pull the arm off , it will always want to go back on down a spline , so you will twist down to the scuttle , it will slide onto the next spline , and when you wipe it will hit the bottom a new arm might be the answer , i.e. a fresh arm comes with no spline cut , this is cut when its tightened onto the spindle you could bend it so it doesn't touch , but this tends to change the blade angle and will judder one way or the other
| The Following User Says Thank You to ric04vrs For This Useful Post: | Wardy (19-11-2007) |
| Re: Adjusting sweep of driver's wiper arm Thanks guys - a new arm might be the way forward then, cost dependant ![]() Cheers, Steve
| | #8 | |
| Moving Stables | Re: Adjusting sweep of driver's wiper arm Quote:
Didnt even mark them
__________________ Run out of CASH | |
Members Car: '97R BMW 328i Saloon Thanks: 679
| Re: Adjusting sweep of driver's wiper arm If the arm is very tight and wiggling it doesn't help, then I'd use a puller... they are only a few quid. I bought a 2/3 way puller from screwfix for about £12 IIRC, and very handy it is too. A new arm should be under £20 Steve. I just paid around that for a new arm for the Passat, and it must have been under £20 or otherwise I wouldn't have bought it!!! ![]()
| The Following User Says Thank You to Tom_vRS For This Useful Post: | Wardy (20-11-2007) |
| Rear Wiper Arm | howlinmad | Fabia I | 2 | 16-11-2007 14:35 |
| Wiper Arm Removal | RobS | Superb | 8 | 23-10-2007 01:12 |
| Adjusting wiper arm | All torque | Octavia I | 6 | 07-05-2007 23:42 |
| Driver's wiper hitting pillar | Yianni | Fabia I | 6 | 26-01-2007 21:51 |
| Octavia Wiper Arm | flyingscot | Maintenance & Performance | 15 | 17-06-2003 15:07 |
