39,398 Members 1,487,289 Posts
Amd OneClick and EGR valve
This is a discussion on Amd OneClick and EGR valve within the Fabia I forums, part of the Skoda Model Discussion Area category; I have been pleased with my Amd OneClick in my fabia vRS. Pre-map I had turned the EGR down to ...
Old 13-04-2006, 19:52   #1
Hardcore
Basil's Avatar
Members Car: Fabia vRS
Question Amd OneClick and EGR valve
Pre-map I had turned the EGR down to its minimum (almost OFF) using VAG-COM, to prevent the crud build-up in the pipes mentioned elsewhere, and to make sure that the engine is not breathing 15% exhaust fumes.
I wondered later if this had been adjusted by the OneClick map at all. Two emails to both the technicians and the customer support went unanswered.
I connected VAG-COM to check on the EGR valve and found that in the modified map, it had been turned back on.
Surely speaking from a performance only point of view, this can't be right?
I plan to turn it back to barely on in short order.
any comments anyone?
Cheers,
Bas
Basil is offline
Old 13-04-2006, 20:08   #2
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Amd OneClick and EGR valve
Im sure the map has been written with it set in the factory position.
EGR only runs a very small amount of the time, whist crusing usually on very light throttle at a sustained speed. As soon as you accelerate its turned off anyhow.
And most of the crud in the intake system comes from the crankcase breather system. The EGR ports directly from the exhaust manifold into the inlet manifold so doesnt actually go around the inlet system anyhow.
www.unit18.co.uk
Lummox is offline
Old 13-04-2006, 20:36   #3
When I had a digital tuning box I had the EGR turned down but the car smoked a lot more than normal. It doesn't smoke now I had it turned back to normal and took the tuning box off.
Does the EGR really make any noticeable difference from a performance POV?
You've been Skoda'taken!
delroy is offline
Old 13-04-2006, 20:42   #4
HellFire's Avatar
Members Car: Skoda Fabia vRS
Interesting! mine smokes a lot less with the EGR turned down.
Metro Blue '06' 5 Door Astra 1.8 SRi
HellFire is offline
Old 13-04-2006, 20:45   #5
I think it may have been down to the tuning box. I was like Jason's car with it on!
I haven't tried it turned down with the tuning box off as the car doesn't smoke at all!
delroy is offline
Old 13-04-2006, 20:47   #6
Cupra Bush King
Lummox's Avatar
Images: 2
It shouldnt really. It designed not to as it only works in certain conditions.
It effectively reduces the volumetric capacity of an engine by 20% (i.e a 2000cc engine becomes a 1600 cc engine) with EGR on, but its programmed to work when you dont need power.
www.unit18.co.uk
Lummox is offline
Old 13-04-2006, 22:37   #7
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
It effectively reduces the volumetric capacity of an engine by 20% (i.e a 2000cc engine becomes a 1800 cc engine) with EGR on, but its programmed to work when you dont need power.
2000cc - 20% = 1600cc
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 13-04-2006, 22:42   #8
Cupra Bush King
Lummox's Avatar
Images: 2
You really ought to stop miss quoting people
www.unit18.co.uk
Lummox is offline
Old 14-04-2006, 10:26   #9
Hardcore
Basil's Avatar
so, if I get this right - EGR on = no problems, EGR off =no problems.
How come I felt that the standard-setting engine was ever so slightly more responsive with the EGR off?
Emissions POV ignored here - surely more pure intake air = better for engine and recirculating some used air= better for emissions?
Oh well...
Cheers for the further info
Bas
Basil is offline
Old 14-04-2006, 18:10   #10
Hardcore
Basil's Avatar
With the EGR Off - i notice that the light throttle surging has gone - before you had to be pretty precise with the accel. pedal to avoid a certain spot. Off seems better.
Oh well...
Bas
Basil is offline
Old 15-04-2006, 08:37   #11
Escorted Estate
Just turn it down on the remap as well
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
