Anyone use wheel spacers?
This is a discussion on Anyone use wheel spacers? within the Fabia I forums, part of the Skoda Model Discussion Area category; Bugger, just kerbed one of my RS6 replicas so thinking about putting my Octy vRS 17's back on. Both need ...
Old 01-05-2008, 11:05   #1
chowy's Avatar
Default Anyone use wheel spacers?
Bugger, just kerbed one of my RS6 replicas so thinking about putting my Octy vRS 17's back on. Both need some refurb of some sort.
I prefer the look of the Octy's but the RS6's really fill the arches better being half inch wider and also ET35 intead of ET38 for the Octy's
Thinking about getting some spacers to fill out the back only as the front look OK with the Octy's but the back needs around 10mm.
Any idea of whether I need longer bolts and if there are any probs with using them?
Present: BMW 130i M Sport 2007 | Titanium Silver (No need to use indicators no more )
Sadly gone: Skoda Fabia vRS 2005 | Black Magic (for pleasure)
Present: Skoda Octavia Ambiente 1.9 Tdi 2005 | Diamond Silver (for work)
chowy is offline
Old 01-05-2008, 11:08   #2
DJM123's Avatar
Post Re: Anyone use wheel spacers?
I had 10mm spacers on the rear of my 2001 ibiza cupra. I purchased them with longer bolts think the cost was about £70 if it helps. Car did feel more stable at the rear afterwards. Hope it helps.
DJM123 is offline
Old 01-05-2008, 12:30   #3
chowy's Avatar
Default Re: Anyone use wheel spacers?
Thanks for that info.
Just did a search for more info and I think it's recommended to get one with a spigot for better support. I might go for the Eibach ones just for the back.
chowy is offline
Old 01-05-2008, 12:33   #4
DJM123's Avatar
I had Eibach on the rear sorted the look out as well.
DJM123 is offline
Old 01-05-2008, 13:08   #5
Mongreller
devonutopia's Avatar
I have 15mm hubcentrics all round on my furby. Fronts out of necessity, rears to match. Handles better, and looks damn hot. Not had any bearings issues yet and been running them for a good year (ish)
I sourced mine through Sarah @ Awesome - Be aware you need 15+mm longer bolts too, which cost me £40 odd alone (not from Awesome though)
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 01-05-2008, 13:54   #6
Johnny Bravo
Johnny50's Avatar
I've got 20mm on the rears only on my Furby.
Fills the arches nicely.
Johnny50 is offline
Old 01-05-2008, 14:02   #7
chowy's Avatar
Is there somewhere that sells the spacers and bolts together?
I think I may go for the Eibachs Pro spacers (10mm) and have seen these for under £40 delivered.
£40 for bolts seem a bit steep!
chowy is offline
Old 01-05-2008, 14:04   #8
Johnny Bravo
Johnny50's Avatar
You could try here.
Wheel Accessories / Wheel Bolts / Euro Performance Car Parts
Not sure how competative their prices are though.
Johnny50 is offline
Old 01-05-2008, 19:19   #9
Mongreller
£40 for 20 specifically longer bolts? £2 a bolt's not too bad, brand new. Then you need longer locking wheel bolt set too! McGard had some thankfully I was able to get for £25ish.
The thing about the 10mm ones is they're not hubcentric - At least pretty sure they won't be. I wouldn't trust any spacer that hasn't got another hub to sit the wheel on. The eibach 15mm ones fit this bill perfectly. There's risk of non-hubcentrics not going on perfectly in line, and thus might cause wobble issues / quicker bearing wear.
Old 02-05-2008, 08:25   #10
Site Sponsor
AwesomeSarah's Avatar
As siad above
But I do believe Forge do them hubcentric , but be prepared to pay for them
Yes 15mm tend to be hubcentric and that is what you need
We do the longer bolts with the spacers for £1.50 each + VAT
If you buy them without spacers £2.50 + VAT each
Sarah
AwesomeSarah is offline
Old 09-07-2008, 01:15   #11
Smokey
Wardy's Avatar
on this one
Mainly for Jason really - I'm looking to run some hubcentric 10s on ye old Fabia (H&R). Could you give me info on which McGards you got and whether they'd be suitable for me (seeing as you're running a 15 spacer). Also, the place you got your bolts from?
Cheers,
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
Wardy is offline
Old 09-07-2008, 11:17   #12
KTP
eeeeeeeeevil.
KTP's Avatar
i have H&R spacers
35mm rear and 20mm front, not had any issues but they've only been on a couple of weeks so far
KTP is offline
Old 09-07-2008, 14:23   #13
Smokey
Wardy's Avatar
35mm spaced on the rear - goodness, I'd be a bit worried about the extra strain on bearing with that amount myself. Got any pics of how it looks now?
Steve
Wardy's Fabia vRS
Wardy is offline
Old 09-07-2008, 14:25   #14
Johnny Bravo
Johnny50's Avatar
I think there's pics on Keiths WIP thread.
I've currently got 20's on the rear, and planning on putting some 15mm's on the front just to balance it out a little.
Any need for bearing concern there ?
Johnny50 is offline
Old 09-07-2008, 14:31   #15
Smokey
Wardy's Avatar
Thanks - just had a look. Didn't realise he was running D90s, so they're actually adaptors, not spacers. Still, a bit too extreme for my liking
Cheers,
Steve
Wardy's Fabia vRS
Wardy is offline
