This is a discussion on Broken rear bump stop? within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi, I was pumping up my tires today when i noticed a bit of loose plastic around the shock of ...
| Briskodian Join Date: Dec 2003 Location: Bolton
| Hi, I was pumping up my tires today when i noticed a bit of loose plastic around the shock of one of the rear wheels. Am i right in saying that this is a broken bump stop (please see attached pic)? Should i replace this or will it be ok like this? I cant say ive heard anything or noticed anything untoward Thanks ![]() |
| It really should be replaced, not a fail on an MOT but its pretty common.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Briskoda Staff Join Date: Dec 2004 Location: Hampshire
| Pretty easy to do as well.
__________________ Stu - Freedom Pimp Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - Hmm, Have a guess...... ![]() SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| the hardest part of doing that is removing the plastic inner arch trim to gain access to the upper mounting bolts.. the bump stops are about £7 iirc like stu says.... easy
__________________ vorsprung durch czechnik |
| | #6 | |
| Quote:
Pah, stanley knife sorts that.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. | |
| Just for info the bump stop is £8.08 + VAT from a dealer...im having my 50k service done next week and theyre doing this at the same time. Thanks guys ![]() |
| | #8 | |
| Briskodian Join Date: Feb 2005 Location: Midlands
| I have just noticed exactly the same thing on my 04 Fabia vRS while I had it jacked up last night. The car has done 55,000 miles and only one of the bump stops appears to have split like this. Is it necessary to replace these as a pair? and is it best while doing it to replace the whole shock absorber, or can you get aray with just replacing the bump stops. Finally is this likely to bean MOT failure or just an advisory? my MOT is due shortly so if I need to get these replaced first, I need to get going. Quote:
| Hi, no need to replace the pair or the shock you just need to replace the bump stop. Ive done another 20k now and the shock is fine. |
| | #10 |
| Managed to replace both rear bump stops this morning and was a supprisingly easy job. Took about an hour and a half to do both. |
| | #11 |
| Briskodian Join Date: Nov 2006
| Where can you get the parts?
__________________ Join the social group : http://briskoda.net/groups/modded+fabia+nutcases/ It make's your car faster! total group bhp to date is 2944.9bhp!!!!!!! |
| | #12 |
| From your local dealer parts department.
