This is a discussion on Cam belt inspection within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi, How do I carry out a check on my cam belt before driving it for a 200miles+ w/end break. ...
| Hi, How do I carry out a check on my cam belt before driving it for a 200miles+ w/end break. it was last changed 2004 at 66k when I bought it a week ago and it's on 109k at the moment. Also, is ther any other major checks similar to cam belt I should look out for. I'm hoping to put off changing it till early next year. Any detailed step by step guide will be very appreciated. Many thanks
__________________ 2002 Skoda Fabia Comfort 1.9TDI |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
| just check the levels (fluids), and tyre pressures, and you should be fine.. it's close to another change though... 120k or 2008 (4 year gap).. if you really want to check it, just have a look to see what sort of condition the rubber's in... if it looks old and you can see cracks, then worry! lol... later models had an 80k change though, I did 80k on the original belt with no probs...
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) |
| Briskodian Join Date: Jul 2007 Location: Leeds
| Its hard to check the belt whilst its on the car as you can only see a small part of it at a time and buy rights you need it off to make a good examination of the teeth to see if there showing signs of wear or starting to crack etc which can best be done by bending the belt. my old volvo s60 d5 was still on its first cambelt at 110000 but i changed it straightaway but i once had a vectra and it snapped its belt at 26k same in my vrs(105k) changed it as soon as i got it then i knew the score with it,the dealers who serviced it all its life were very unhelpful when it came to releasing information quote" i remember that car weve never put a belt on it" id get it done a.s.a.p its not dear,but leave it and youll kick yourself into next week if it snaps and kills your valves etc.better safe than sorry as most on here will agree |
| | #4 | |
| Quote:
Chris
| Thanks for the advice. BTW, how much will this set me back?
| Depends on where you go, expect £250-£400.
__________________ Unit 18 Automotive Services |
| Can anyone recommend me a reputable and reasonably priced garage in London (SE). Thanks
