39,396 Members 1,487,260 Posts
Clearing or resetting the ECU?
This is a discussion on Clearing or resetting the ECU? within the Fabia I forums, part of the Skoda Model Discussion Area category; I have red on hear a few times people talking about clearing/resetting the ECU. 2 questions : 1: what, if ...
Old 05-05-2007, 20:58   #1
GPW
Dieselslave
GPW's Avatar
2 questions :
1: what, if any benifit would this have on the engine?
2: if it is a benifit how is it done?
GPW is offline
Old 05-05-2007, 21:03   #2
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Clearing or resetting the ECU?
None as far as I know really.
www.unit18.co.uk
Lummox is offline
Old 05-05-2007, 22:46   #3
rossm's Avatar
Don't know how its done without special eqipment and doubt there are any benefits to the actual engine through resetting the ECU. I imagine a VAG-Com would do it, but I reset mine using a star performance switchable remap module which lets me put the ECU back to standard with one program or change to the performance program.
There are some known electrical gremlins with the Fabia that may be resolved by resetting the ECU, such the one-touch electric windows feature not working (fairly common).
I also believe that some ECUs are adaptive to the driving conditions and type of fuel your using. For example, if it was a petrol engine and you were using cheap supermarket fuel, but then filled up with Shell V-Power normally the ECU would take a while before it got used to the new fuel, but resetting it would allow it adjust quicker for the better performance fuel. BTW - This bit is accoding to 5th Gear when they done the Reort on different Fuels and the effect on BHP, so don't blame me if its utter tosh!!
rossm is offline
Old 06-05-2007, 08:40   #4
Cupra Bush King
Lummox's Avatar
Images: 2
There are many ECU's in the car, the ECU for the windows is quite different than the one for the engine.
www.unit18.co.uk
Lummox is offline
Old 06-05-2007, 16:24   #5
Johnwg's Avatar
Members Car: Octavia II VRS
I've been informed that disconnecting the battery for '30 mins' resets the ECU (engine ECU from what you say I presume?), is this the case Lummox?
Also informed that doing this means that mods such as pannel filters are 'adapted' for instanty rather than having to wait for the ECU to adapt over how many hundred miles is takes?
2007: Octavia II VRS TDI in Black
Johnwg is offline
Old 06-05-2007, 18:38   #6
rossm's Avatar
Would disconnecting the battery for 30 mins reset all the ECUs then?
I've found that by reprogramming the ECU with the standard map resolves the windows issue for me, the process of doing that must link in with the window ECU somehow, don't know the technicalities though.
rossm is offline
Old 06-05-2007, 18:40   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Yes it will blank all adapted values.
Cant see why the windows would be connected to the engine.
www.unit18.co.uk
Lummox is offline
Old 07-05-2007, 10:43   #8
GPW
Dieselslave
GPW's Avatar
Thanks for the replys so in answer It dosnt do a great deal but would help the engine accept small changes faster.
Cheers
GPW is offline
