Constant pull to the left
This is a discussion on Constant pull to the left within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello all, I'm having a problem of my Furby constantly pulling to the left even though it's been tracked and ...
Old 03-09-2006, 08:47   #1
Rastanking's Avatar
Default Constant pull to the left
Hello all, I'm having a problem of my Furby constantly pulling to the left even though it's been tracked and the tyres are the correct pressure, has anyone else suffered this problem? Does anyone know what could cause this and should I ask my dealer to look at it as it's still under warranty?
Thanks in advance
Rastanking is offline
Old 03-09-2006, 08:56   #2
Anders's Avatar
Default Re: Constant pull to the left
How much pull are we talking about?
Anders is offline
Old 03-09-2006, 09:01   #3
I parked up 1st
ric04vrs's Avatar
yep , mine pulls to the left all the time , tracking ok etc , only started doing it after changing the front tyres to Dunlops from the original Michelins , had Toyos on the front for the Ring trip , pull was a lot less noticeable , so the first thing you could try is swopping the front wheels over side to side , assuming not directional tyres, to see if there is any improvement in the pull , or if the tyres are directional you will have to try the rear wheels on the front . Obviously if there is an improvement you will know that the tyres are causing the problem . another cause that i will be looking into shortly is the lower arm rear bush , i think i will be changing them for the solid version fitted to the Seat Ibiza Cupra , this will stop a lot of the back and forth movement in the arm especially under braking HTH
not so bored now
ric04vrs is offline
Old 03-09-2006, 10:37   #4
daz_vrs's Avatar
mines always done it. with standard wheels and tyres, and with new ones. ive just learned to live with it.
skoda- loved by the intelligent....hated by the plonkers!!
daz_vrs is offline
Old 03-09-2006, 11:11   #5
Anders's Avatar
Smile Re: Constant pull to the left
Mine pulled some to the right, but after getting new tyres 2 week ago, its straight as an arrow
Anders is offline
Old 03-09-2006, 12:50   #6
ScoobyChris's Avatar
Seems to be a trait of a lot of Skodas, although some suggest it's just the camber of the road..... never noticed it on any other cars I've driven
Chris
ScoobyChris is offline
Old 03-09-2006, 13:42   #7
Neily03's Avatar
My new one does, only very slighly and i'm pretty its just the camber of the road pulling it left as the more camber the more it pulls.... still onl;y very slight....
Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB.
Neily03 is offline
Old 03-09-2006, 14:37   #8
Mine's done it from new - dealer said it was normal - drove a couple of demos to makes sure and it seems they all do it to a degree. Shouldn't be doing it much, just enough to be noticable.
Bike with engine coming soon...
SteVRs is offline
Old 05-12-2006, 00:58   #9
had 2 fabia's both from new with diff wheel/tyre combinations and different tyre manufacturers - both pull left and are very sensitive to camber. Ironically if you drive on the rhs they track straight as if the geometry has been set/manufactured for the continents camber of the rh side of the road. Have been down to Nice twice and on the French roads its fine. You can try it here at your own risk.
It might be 'normal' but its not how it should be. Other manufactures set castor/camber geometry for the UK and their cars drive straight [Octavia is ok]although they will drift slowly to the kerb but not as annoyingly as the Fabia. Tyre wear is even.
sk_o_da is offline
Old 05-12-2006, 10:19   #10
left briskoda.net
Snoopie's Avatar
It would be the camber of the road. Anders said his car is pulling to the right, and he's from Norway. Right hand drive i believe..
Snoopie is offline
Old 05-12-2006, 11:57   #11
If that's the case why don't other makes of cars do it? Skoda is the only one I've owned where I've noticed it
Chris
Old 05-12-2006, 12:16   #12
left briskoda.net
Snoopie's Avatar
The Fiat Marea we have does it when i drive it now and again. Also the Ford Fiesta I had done the same thing. When i took the Fiesta over to Portugal, It happened on the right. Same with the Fabia.
Either you've been lucky, or i've been sold constant Dud's. They can see me coming from a mile off!
Snoopie is offline
Old 05-12-2006, 12:19   #13
Or the roads I drive on have less camber
Chris
Old 05-12-2006, 12:51   #14
chris_newell41's Avatar
how about driving on the wrong side of the road and see if it pulls right?
obviously on a private road!
Fabia Vrs Blackmagic!
Xenons, Cruise Control, Heated Seats and ESP
Wednesday 12th may 2006 was my VRS day
Proper Mudflaps for VRS Clicky
chris_newell41 is offline
Old 05-12-2006, 12:58   #15
Mongreller
devonutopia's Avatar
Mine pulls to the left, when I'm on the correct side of the road, and I only had a 4wa check about 3 weeks ago. I can only put it down to road camber. There are some moments, such as driving down to a roundabout on a dualie bit, turning right, when the car will pull to the right under braking.
I'm not worried about it - for me it's merely a gentle drift when you release the wheel - I don't feel it pulling or anything whilst I have my hands on the wheel.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 05-12-2006, 13:05   #16
left briskoda.net
Snoopie's Avatar
That's my point. In France Spain and Portugal, My Fiesta and Fabia pulled to the right. They both pull to the left in the UK.
Snoopie is offline
Old 05-12-2006, 13:18   #17
Mine doesn't pull either way across the whole width of the road It must be special
Chris
Old 05-12-2006, 13:50   #18
left briskoda.net
Snoopie's Avatar
I reckon this would pull you to the left!
Snoopie is offline
Old 05-12-2006, 17:08   #19
I parked up 1st
ric04vrs's Avatar
WTF ?
not so bored now
ric04vrs is offline
Old 05-12-2006, 17:52   #20
Loz
Bad Loz!!
Loz's Avatar
Location: here..................... sometimes there........
I thought all cars were supposed to pull (a small amount) to the kerb? I have never noticed mine do it excessively tbh.... but surely, if you sat in any car and let go of the wheel it isn't just gonna go in a straight line, bumps & dips in the road would prob gently move the wheels a different way?
Lorraine- AKA Loz, Lozkins, Lozza, Lozzy, Lozlet, Lozzette, Lozzle, Lozraine, Lozalot, Lozatron, Lozatronic, Lozatroonathoone, Lozlatina, Loztalot, Lozingtonrain, Lozinator, Lozenge, Lozenger, Lozmanaught, Lozzy Loo, Lozzybear, Lozzy-wozzy-dooh-dah-day, () CouLoz of the rainbow, Lozano, Lozvaldo, Lorraineo, Lorrainickle, Lorrainus, Lez, Lezkins, Randomer & Mizz LB
Can't change the way I am, sexy, naughty, bitchy!
Loz is offline
