Coolant leak caused by PD160 air intake
This is a discussion on Coolant leak caused by PD160 air intake within the Fabia I forums, part of the Skoda Model Discussion Area category; As the title Driving home things got a little hot under the bonnet. On inspection I found a coolant leak ...
Old 03-05-2007, 20:08   #1
GPW
Dieselslave
GPW's Avatar
Exclamation Coolant leak caused by PD160 air intake
As the title
On inspection I found a coolant leak coming from a small hose which is part of the coolant return. I have had a PD 160 air intake fitted to my VRS for around 25K miles and due to engine movement and vibration the larger air intake pipe has been rubbing against this hose and eventually worn through.
See pic for hose and postion.
Please everyone who has the PD 160 intake fitted check your cars to see that yours is not doing the same.
I have fitted a new hose and there has been no harm done. This can easily be avoided by 2 possible methods.
1: simply wrap the hose in insulating tape to act as a buffer.
2: loosen the 2 retaining spring clips and twist the hose round to give sutable clearance.
I have done both to mine now.
Happy driving
GPW is offline
Old 03-05-2007, 20:30   #2
Skonda Fabic
Default Re: Coolant leak caused by PD160 air intake
Good advice there. Cheers
ChrisRs is offline
Old 03-05-2007, 20:37   #3
Dervlova
Joff's Avatar
Just updated the guide with a pic... bit too late for you tho
http://www.briskoda.net/forums/fabia...-thread/57557/
A kitten is killed every time you don't use the search
Joff is offline
Old 03-05-2007, 21:08   #4
Life under my bonnet never seems to chuffing end.....
Thanks for the nod GPW
oliverreed is offline
Old 03-05-2007, 21:15   #5
Dervlova
Joff's Avatar
I would have told you on Sunday anyway
Joff is offline
Old 03-05-2007, 21:20   #6
Mouse's Avatar
Yep. Mine started chaffing 50 miles later. Thankfully i spotted it it and did the above. Good advice. Nice to see the DIY guide updated.
Black Magic Fabia v/RS
Skoda Fabia VRS ! Practical & Exciting !
Mouse is offline
Old 03-05-2007, 23:08   #7
Chris GB's Avatar
Thought that was a known issue with this mod? Surely at install it would be obvious?
Chris
Red Fabia vRS. Gone but not forgotten.
Chilli Red / white Mini Cooper Diesel with dual controls.
Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud.
Details here My MR2 Page
Chris GB is offline
Old 03-05-2007, 23:33   #8
Dervlova
Joff's Avatar
Chris
People might not realise that the engine moving when under load would cause the pipe to rub against the intake pipe.
Joff is offline
Old 03-05-2007, 23:40   #9
It's all good
Decron's Avatar
Common sense should prevail.
I fitted a piece of garden hose with cable ties over the pipe to prevent damage straight after the upgrade. There are threads on here somewhere detailing it, some people just manipulate the pipe with cable ties to prevent chaffing.
Decron is offline
Old 03-05-2007, 23:41   #10
Dervlova
Joff's Avatar
They sure do
Joff is offline
Old 04-05-2007, 05:58   #11
GPW
Dieselslave
GPW's Avatar
Chris
I just made a easy mistake. I posted the thread to alert others people to remember and check. Just tring to help other to avoid a bit of hassel.
perhaps after helpful responces like
"common sence should prevail" and as above "surely at install it would be obvious" I wont bother again
GPW is offline
Old 04-05-2007, 07:24   #12
Hardcore
Basil's Avatar
Smile Re: Coolant leak caused by PD160 air intake
yep - really good thing you've pointed it out to emphasize this to everyone - the chafing problem was only mentioned "in the small print" on a Brisk search- nice wide tie-wrap as above on mine since the install - essential part of the mod IMHO.
Tie-wrap locking ties are the quickest, easiest and most secure - takes all of 2 minutes to prevent a potentially costly problem...
Thanks again for reporting this m8
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 04-05-2007, 07:32   #13
It's all good
Decron's Avatar
You really shouldn't take it like that, your post was informative, concise and it has good value to forum.
I don't think either response was meant kick you in the sack!
Decron is offline
Old 04-05-2007, 07:39   #14
Mongreller
devonutopia's Avatar
Well, this is a new bit of information to me, so I applaud the thread starter! Although as mine is not attached to the slam panel, it's moves about a bit more and I've never had the chafing issue.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 04-05-2007, 09:19   #15
rider of sharks
sharkrider's Avatar
Originally Posted by Joff View Post
They sure do
it is known... I posted up on it about a year ago... I reccomend the plastic tie, as done above
Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red....
Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!)
sharkrider is offline
Old 04-05-2007, 11:27   #16
spyke85's Avatar
Where is the plastic tie fastened around? Will have a look on my Ibiza later
05 Seat Ibiza FR TDi - PD160 intake & Green Panel filter
142bhp / 250lbs/ft - Awesome GTi 9/9/06
spyke85 is offline
Old 04-05-2007, 14:03   #17
Dervlova
Joff's Avatar
Just part of the engine casting, should see where with the engine cover off.
Joff is offline
Old 04-05-2007, 17:27   #18
Chris GB's Avatar
No offence meant sir, just thought it was covered as part of the how to guide. Casting ones mind back, I don't remember reference to it, however, when moving stuff about under the bonnet, one should always be aware of potential clearance problems, not only when modding either.
Chris
PS Still a worthwhile thread as it will cover the subject for future searches.
Chris GB is offline
Old 04-05-2007, 17:51   #19
Skonda Fabic
I have posted here to applaud the thread also.
TBH there are so many threads that missing one is very easy.
To write, "....do a search" or " ..its obvious" does not help and is downright rude.
However, I applaud your apology ChrisGB
ChrisRs is offline
Old 05-05-2007, 05:58   #20
GPW
Dieselslave
GPW's Avatar
Just to let everyone know and how easy it it for people to be confused by doing a search on here due to so many postings.
this is the information i followed , and on offence ment to the help that VRStu gives people and I read and was aware of his disclamers.
Fabia-vrs.com - PD160 Intake Guide
happy driving
GPW is offline
