This is a discussion on Coolant loss within the Fabia I forums, part of the Skoda Model Discussion Area category; Just noticed that i have been losing coolant its only a little bit.Its about 100mls enough to take the water ...
| Briskodian Join Date: Dec 2007
| Just noticed that i have been losing coolant its only a little bit.Its about 100mls enough to take the water level in expantion tank from max to min every 2 weeks or so.Checked all hoses they seem to be ok,i can see coolant on the bottom tray ,when you look at engine bay its to the right where the bottom hose fits to the radiator checked all connections there they seem/look dry,has anybody got any ideas where it may be coming from any help most welcomed. ![]() |
| Briskodian Join Date: Sep 2006 Location: Porth (Rhondda, South Wales)
| The rubber surround on the radiator temp' sensor?
__________________ ![]() Currently 42K, Initially patch reliability, fixed by dealer under warranty. Not missed a beat since. Reliable and Nippy. 32+ MPG (rubbish), Cheap Insurance. |
| The Following User Says Thank You to BoilingPoint For This Useful Post: | clairelouise (14-06-2008)
| Hi,thanks for the info will investigate further, where can i buy a new seal from skoda dealership? ![]() |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| It will be the rad fan sensor. Skoda dont put a seal on it from factory and they leak. Will need a seal put on.
__________________ MK2 Golf GTi - APX 225bhp 1.8T - Emerald K3 - Quaife ATB - VR6 Widetrack - VR6 brakes front and rear - Neuspeed ARBs - Speedline alloys - H+R coilovers - Powerflex bushes - Helix clutch G60 flywheel - Adjustable solid top mounts - Custom engine bay - Tornado Motorsport MSA cage - and lots lots more. |
| The Following User Says Thank You to Lummox For This Useful Post: | clairelouise (14-06-2008)
| Hi thanks for the information will get my brother inlaw to take a look at it,thanks again. |
| Hi thanks to everybody regarding coolant loss, it was the seal around the radiator sensor will get it fixed in the next couple of days. |
| | #7 | |
| Quote:
