This is a discussion on creaking seat within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi I'm just coming up for 4000 miles in my fabia 1.9 tdi estate. The driver's seat has developed a ...
| Briskodian | creaking seat Hi I'm just coming up for 4000 miles in my fabia 1.9 tdi estate. The driver's seat has developed a persistent creak. Do any of you know if this is a common problem, or one easy to fix? Just wondering if it's something a squirt of WD40 will fix, rather than the hassle of taking it to the dealer for repair. Cheers James |
| Briskodian Join Date: Aug 2006 Location: milton keynes
Members Car: Skoda Fabia vrs Thanks: 0
| Re: creaking seat i had the same problem at 5500 miles dealer changed the seat base before even checking it the tech turnt round and said it is a common problem |
| Briskodian Join Date: Aug 2006 Location: Istanbul ,TR
Members Car: 2007 Roomi 1.4 85 BHP Thanks: 110
| Re: creaking seat I had the similar problem and moved the seat one click forward (or backward) and the creak stopped!
__________________ 2007 Roomster 1.4 16V - after 3 years with 2004 Fabia 1.2 12V http://www.skodaclubturkey.com |
Members Car: Fabia 1.9 PD TDi Elegance Thanks: 0
| Re: creaking seat I have the same problem in my 1.9 Tdi and it is becoming quite annoying. Armed with this info, looks like a trip back to the dealer. |
| Briskodian | Re: creaking seat i had my base replaced, solved the problem. I think its a common fault |
| Briskodian | Re: creaking seat Was certainly a known problem on the octy, from what my local dealer said, but I don't know if it was common or just known.
| Briskodian Join Date: Aug 2006 Location: Wrexham
Members Car: Golf GT TDi Thanks: 25
| Re: creaking seat is it expensive to get fixed? Mines been doing it a while and it's getting more irritating ![]() |
| | #8 | |
| DisturbedMonkey Join Date: Jan 2006 Location: In a mental home, whacked out on happy pills talking backwards with Einstein :D
Members Car: Skoda Fabia 1.4TDi Estate Thanks: 0
| Re: creaking seat Quote:
![]() An un-qualified oppinion here... but I believe that as we sit in the seat the hieght lowers over time and it needs a little pump now and then to keep pressure in the gas cylinders.... my guess anyhow ![]() Q
__________________ Insanity is not an illness.... it's a way of life !! | |
| | #10 |
| Briskodian | Re: creaking seat when i took mine in the dealer lubed it first as skoda stated a replacment base is expensive. Ended up replacing the base anyhow. |
| | #11 |
| Briskodian Join Date: Jan 2005 Location: kent
Members Car: OctaviaElegance 130 TDI Thanks: 26
| Re: creaking seat Had this prob on my Octy and after 2 years still in warranty , took it to the dealers and they replaced base and back , good deal as i had done 45k miles , and now have a new seat . However when they replace them they reuse the original covers . |
| | #12 |
| Briskodian | Re: creaking seat Thanks all for the input. Moving the seat back or forward doesn't work, nor does adjusting the height. Looks like a visit to Mr Dealer... |
| | #13 |
| Briskodian Join Date: May 2006 Location: Newport
Members Car: Fabia vRS Thanks: 3
| Re: creaking seat All of my seats have squeeked at some point - started with driver so took it to the delaers only for the back to do it when I left the garage!!! Went back for that to be sorted and the day I left, my passenger seat is doing it now!!! Going slightly mad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________ Gez http://www.slide.com/r/5JBwR9-47j95A...&view=original rolling on 18's.........smooth and shiny! |
| | #14 |
| Briskodian | Re: creaking seat Mine does it to, I just turn the radio up a little more. Will go try get it sorted though now |
| | #15 |
| Briskodian | Re: creaking seat my drivers side had a new seat base about a 2 months ago (5000 miles) it has just started to do it again so when it has its service next wed they are going to have another look at it and also change the drivers side fron fog as it keeps misting uprichard |
