This is a discussion on DIY water/meth injection web resources within the Fabia I forums, part of the Skoda Model Discussion Area category; Makes for some interesting reading, if you're so inclined benefits: Diesel Water / Methanol FAQ's Where Do I Position My ...
| hardcore modder Join Date: Feb 2006 Location: Bahrain
| Makes for some interesting reading, if you're so inclined ![]() benefits: Diesel Water / Methanol FAQ's Where Do I Position My Water Methanol Injection Nozzles DIY system guide: Do It Yourself Water Alcohol Methanol Injection and another: Browser Warning Alcohol Information Water Injection, declined in popularity, why?? - The mkiv Supra Owners Club Cheers Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod Last edited by Basil; 20-05-2008 at 16:42. |
| Briskodian Join Date: Dec 2007 Location: Chippenham
| Looking good mate. But my issue with these kits is...Surly the alcohol/methanol would wash your bores of oil?? Anyone care to shead light? Dave
__________________ '53 Fabia vRS. PD160 intake, Green Cotton Filter, Pikey Intercooler Mod, 312mm Brakes. Debaged Rear End. Fixed The Rear Door Leak! Ready to fit: 19Row Fuel Cooler, Braided Fuel Line, NACA Duct, Wheelarch Pikey Mod. To Buy: FSD's, Pro1.2's, FMIC, LSD, Devils Own Water/Meth Injection, Clucth, SM Flywheel, Hybrid Turbo + Remap. ££££ |
| | #3 | |
| Mongreller Join Date: Apr 2003 Location: Ooo-ar, Oi be from Devonshire
| Quote:
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. See the mongrel's 260bhp Dyno Video! | |
| Briskodian Join Date: Oct 2007 Location: Kilkenny, Ireland
| Basil you are a genius, thanks. As Jason points out, the trick with the water is to have the mist droplets as small as possible (dependent on the injector nozzle sizes) and to inject it into the air-flow between the inter-cooler and the inlet manifold to provide additional cooling and free fuel. Too much water and you get "quenching", too little and there is no cooling and no power increase. One product I have read the specs for (BEWARE: marketing marketing marketing) makes the following claims: 100% water - power up by 20 - 30 HP 75 / 25% water / meth mix - power up by 40 - 60 HP 50 / 50 % water / meth mix - power up by 70+ HP. I have been informed that my car (specs supplied to system manufacturer) with no other upgrades or changes will show a top-end power increase in bhp of 15 / 25% (from 175 bhp to 200 or 219 bhp). Torque figures were a bit of a mystery. With uprated diesel injectors, a new turbo and a new map, who knows? (no intercooler change needed, by all accounts, just inject more water / meth mix). Just a word of warning for anybody considering going down this road - you cannot use methanol if you have aluminium piping from your intercooler as the aluminium and mathanol will react chemically. |
| | #5 | |
| Quote:
Glad I knew that in advance. ![]() Looks like I'm drilling the inlet manifold then! ![]() ![]()
| whats the manifold made of?? Cast? Kit will be ordered if so. Wasnt 100% sure which kit to order tho. Dave
