This is a discussion on Erm, is corrosion like this normal on rear brake discs within the Fabia I forums, part of the Skoda Model Discussion Area category; Noticed this on my passenger side rear brake disc today. Other one is fine.... Is this normal? If not can ...
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
Members Car: 04 Fabia vRS (180/300) Thanks: 26
| Noticed this on my passenger side rear brake disc today. Other one is fine.... Is this normal? ![]() ![]() If not can someone point me in the direction of replacement OEM discs/pads OR a well priced disc/pad combo. Whichever is best really.
__________________ '04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints |
| Briskodian Join Date: Feb 2005 Location: A30 Newquay Cornwall
Members Car: Fabia 1.9 TDI Thanks: 39
| Re: Erm, is corrosion like this normal on rear brake discs i think mine look like that though im in need of replacing them real soon so i think im gonna get some upgraded breaks saw some on ebay with grooves! they looks nice! ![]() taking a closer look i dont think i've lost that much metal... ![]()
__________________ ![]() Fabia Bohemia Mods - 16" BBS Montreal's, Blaupunkt Rome nav, fitted front and rear areo wipers, rear OEM speakers fitted, vw damped grab handles. |
| Skoda Junkie! Join Date: Apr 2007 Location: East Lothian
Members Car: Skoda Fabia VRS 130 Thanks: 387
| Re: Erm, is corrosion like this normal on rear brake discs Hmm never really looked at my rear discs, might be worth a look later. |
| Smoggy Hooligan Join Date: Oct 2007 Location: Kilmarnock
Members Car: Skoda Fabia vRS "55 reg" Thanks: 99
| Re: Erm, is corrosion like this normal on rear brake discs ouch! that dobt look good, joel
__________________ Yeah, its's a Skoda.....so what ![]() (and its a Diesel )I'm supplying Stainless Boost Pipes ![]() Doing some investigating into Stainless Sump Guards, Back Box Replacement Pipes and all other Stainless Steel Stuff ![]() ![]() |
| Briskodian | Re: Erm, is corrosion like this normal on rear brake discs That is one heck of a lip. Are the discs still above minimum thickness? That size of that lip suggests they are probably not to me. If they are a still good in the swept area, then get out a wire brush and some fine wet and dry. Wire brush the large rust off the edges and then just run the wet and dry over the exposed surface a few times to get it smooth so you don't damage the pad from any sharp bits left. If the discs are close to their minimum thickness then I'd probably just get new discs anyway as they are fairly cheap. 312mm vented fronts are only £60 for a pair from GSF so solid rears would probably be in the region of £30 for the pair EDIT: Yes rust on the unswept parts of discs is perfectly normal ![]()
| Re: Erm, is corrosion like this normal on rear brake discs I checked the thickness and it seems they are above the 7mm minimum. But they dont look too healthy. Reckon they are daffy ducked?
| www.oscarli.com Join Date: May 2005 Location: The home of witty banter™
Members Car: Skoda Fabia vRS Images: 1 Thanks: 91
| Re: Erm, is corrosion like this normal on rear brake discs Standard discs are not to pricey, and pads from skoda are £15 iirc. Not a big job. Mine went like that too. The rear brakes do virtually nothing on the Fabia from my experience.
__________________ Official 0 to 60 mph - 5.85 seconds. Standing 1/4 mile - 14.3 seconds. 251.5 BHP and 400 lbs/ft of torque. Oh - and 55 mpg on a run ![]() ![]() My car is for SALE!! ![]() |
| Briskodian | Re: Erm, is corrosion like this normal on rear brake discs You could clean them up, but it depends if you value your time. If you value your time highly, then a new set of discs and pads will probably cost the same as the hour and bits spent cleaning those up. I think if it was me I'd get the wire brush and give it a going at. while still on and do half, turn the disk and do the other half. If it doesn't improve it quickly I would just get some new ones. Seen it on other cars too but as Dave said the rear brakes don't really do much so this is not unexpected.
| Re: Erm, is corrosion like this normal on rear brake discs In the end I've got some Mintex OEM replacements off ebay, pads and discs for £40
| | #10 |
Members Car: Black Magic Fabia vRS Thanks: 346
| Re: Erm, is corrosion like this normal on rear brake discs Mine ended up like that after about 40k, and was advised to get them replaced because they'd have been an MoT failure had the car been up for its test at that time. The ZeroSixties I got instead seem to be in much better state considering they've been on for a good 20k now... (Although what with the brakes being over-servoed as ever on modern cars, they and the Mintex Extremes made for some, erm, 'interesting' moments on the way in in the sleet this morning... That or the Pirellis - am beginning to wish I'd stuck with the Toyos )Anyway, back on-topic, I wouldn't say they were 'normal', because they shouldn't really get that tatty, but it's definitely not uncommon on the Furby...
__________________ |
| | #11 |
| Briskodian Join Date: Jan 2008 Location: Dublin, Ireland
Members Car: Fabia Vrs Thanks: 31
| Re: Erm, is corrosion like this normal on rear brake discs I would have thought that a good time to upgrade to TT brakes. Good to hear it didn't cost you the Earth to fix though Joel.
| | #12 |
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Re: Erm, is corrosion like this normal on rear brake discs These are rear brakes Vista, there aren't any worthwhile upgrades for the rears. As Dave said, they don't do a lot and tend to corrode. Not seen any quite as bad as that though ![]() Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| | #13 | |
| Briskodian | Re: Erm, is corrosion like this normal on rear brake discs Quote:
They are underused as it is on the fabia, so putting bigger brakes there will mean even more problems. The Mintex OE replacement you've got should be just fine assuming it's the real deal
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| | #14 |
| Re: Erm, is corrosion like this normal on rear brake discs ...plus the vRS uses the same rear discs / calipers as the 2WD TT did anyway... ![]()
| | #15 |
| Briskodian | Re: Erm, is corrosion like this normal on rear brake discs I wouldn't bother cleaning them up as you might taking more corrosion off one side than the other and end up with an unbalanced disk. Either leave it, if it's above mon thickness, or replace IMHO.
__________________ Octavia 4x4 |
| | #16 |
| C+ à Paris! Join Date: Sep 2003 Location: Tilehurst, Berkshire
Members Car: "Fake" Black Magic vRS Thanks: 21
| Re: Erm, is corrosion like this normal on rear brake discs One of the MOT items my Fabia failed on a few years ago was the rear brakes - excessively pitted. It does happen, they aren't used that much, and in my case, the pad usage was all squigly matching the pits and grooves of the disc. In the end, I just changed the lot - discs and pads were around £50 for a complete set. If you do decide to change yourself, you'll need a windback tool because the brake pistons rotate on a corkscrew thread as they come out. I did write up a guide about it ![]() Last point: it's worth checking both wheels - again, I had / still have uneven wear from one side to the other and the handbrake is a bit dodgy because the calipers seem to get "stuck" sometimes and not release properly when you drop the handbrake.
__________________ Xavier |
| | #17 |
| Briskodian Join Date: Feb 2008 Location: Herts
Members Car: Skoda Fabia 3 estate 1.4 16v Thanks: 24
| Re: Erm, is corrosion like this normal on rear brake discs This is a very interesting thread. Can I ask what sort of driving you chaps who've had rear disc corrosion problems do? I do 44 miles per day on country lanes. I'm just awaiting a Fabia 3 with ESP so will have rear discs brakes. Is this issue associated with low mileage around town or with cars used for average/above average mileage on faster roads too? I'd problems with brakes in the past and was told part of the problem was that I was being too light-footed on the brake pedal and to brake more firmly on occasions to keep everything healthy. How often do Skoda recommend brake fluid changes? On the Vauxhalls, I changed mine annually. The other thing I've noticed is that the tyres fitted as standard on the Fabia 3 are W-rated and good for up to 168 mph. It seems a bit excessive on a car with a maximum speed of 109 mph! Jo |
| | #18 |
| Re: Erm, is corrosion like this normal on rear brake discs I do 15-18000 miles per year; mostly on motorways. But then I wouldn't be braking very often on the motorway, so it's not necessarily a good thing in terms of preserving the brake discs... I have non-Skoda discs on now, which seem to be lasting a bit better, but then I also have fast road pads which might help get the discs hotter???
| New rear brake discs for 2yr old vrs?? | troll | Fabia I | 20 | 09-09-2007 02:02 |
| Front & Rear Brake Discs | Fezboy | Octavia I | 7 | 16-07-2007 11:40 |
| Rear 4x4 brake discs - fitment confirmation please... | FocusZtec | Octavia I | 7 | 04-01-2007 23:55 |
| Brake Disc Corrosion | bertJ | Fabia I | 8 | 05-01-2005 18:19 |
| 312mm front and 256mm vented rear brake discs on a normal Octavia?? | inquirer | Maintenance & Performance | 15 | 14-04-2004 09:17 |
