ESP on ESP off
This is a discussion on ESP on ESP off within the Fabia I forums, part of the Skoda Model Discussion Area category; Just wondering how many fabia drivers turn off the esp as soon as they start the engine Compared to briskodians ...
Old 02-09-2006, 00:35   #1
okeh's Avatar
Default ESP on ESP off
Compared to
briskodians who prefer to have it active whilst they drive
And
What gains the non esp drivers experience due to turning it off
okeh is offline
Old 02-09-2006, 02:41   #2
jifster's Avatar
Default Re: ESP on ESP off
Compared to
And
I've had my car 2 years now and never switched it off and now i'm scared to incase I find out I can't actually drive.
jifster
Black Magic Fabia v/RS with Forge Motorsport FMIC, Milltek exhaust system, Eibach springs & dampers, 312mm brakes, Cupra intake, Seat upper strut brace, Jabbasport rear ARB, Xenons, Cruise, Sunroof and ESP. Pioneer: DEH-P8600MP.
jifster is offline
Old 02-09-2006, 10:24   #3
Hardcore
Basil's Avatar
Talking Re: ESP on ESP off
There was a poll on this a while ago.
There is a way to even turn it off with VAG COM apparently.
I'm sure that a relay connected to the ignition live and the switch circuit could do the same thing
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 02-09-2006, 11:11   #4
ScoobyChris's Avatar
Why pay £500 for an option and then turn it off?
Chris
ScoobyChris is offline
Old 02-09-2006, 11:17   #5
Briskodaholic
Tom_vRS's Avatar
Chris
Madness. ESP won't hinder you in anyway unless you want to drive like a hooligan or on a track... so for normal driving, leave it on.
97/R BMW 328i in Boston Green.
Don't miss the new DR COLORCHIPS GROUP BUY!
Tom_vRS is online now
Old 02-09-2006, 11:27   #6
RICHARD
Fabia 12v's Avatar
It'll save you life switched on
First Car: Skoda Fabia MK1 1.2 12v Comfort
Replaced with: Volkswagen Golf MK4 GT 1.9TDI
Replaced with: Seat Ibiza MK4 Sport 1.9TDI
Replaced with: Volkswagen Polo MK5 Ltd. Edition Sport 1.4 16v
To be replaced with: Volkswagen Golf Mk5 Final Edition GTI 2.0TFSI 16v... early 2009.
Fabia 12v is offline
Old 02-09-2006, 11:40   #7
r32
Not quite true in my experience. ESP hates bumpy roads, particularly bumpy corners. I find on the R it cuts in when it shouldnt purely cos of the bumps. I also find that if you boot it out of a junction turning at the same time it also sometimes cuts power just when you don't want it to.. especially with 4wd.
I've therefore got into the habit of turning ESP off when I know I need to make a quick exit from a junction and on certain bumpy corners when I know it is going to kick in annoyingly!
I have played with the car and felt ESP working though. The way it can brake an individual wheel so straighten up understeer or a possible tail slide is very clever, so the majority of the time I leave it on.
r32 is offline
Old 02-09-2006, 11:51   #8
Ants's Avatar
If your driving properly, it should never interfere, same with ABS. Even if you driving hard, feeding power on and braking smoothly shouldn't cause driver aids to be needed.
Fair enough, there will be variations in road surfaces that will make it much harder to judge grip levels, but day to day, why would you want turn it off!
Ants
Ants is offline
Old 02-09-2006, 14:23   #9
Hardcore
Basil's Avatar
Sorry if I made a mistake - of course ESP is different from ASR - I find that the throttle response is "perkier" (hmm) with ASR off. Don't have ESP (although I sometimes get a strong hunch....)
I keep the ASR on usually except when feeling particularly naughty...
Basil is offline
Old 02-09-2006, 14:28   #10
Briskodiodion
TeflonTom's Avatar
my 2.0 fabia definately accelerates quicker without the asr switched on.
vorsprung durch czechnik
TeflonTom is offline
Old 02-09-2006, 14:34   #11
Thirdtimeluck's Avatar
How do you work that one out?
Surly it will be just the same but it will control any wheelspin you might encounter?
2.0 (mustang slayer ) Furby
Thirdtimeluck is offline
Old 02-09-2006, 15:16   #12
Escorted Estate
Nope, as the ASR is IMHO not particularly great - the problem is mainly that it kicks in very hard but just too late, cutting power a fair bit. The wheel regains grip, power goes back up after that, but you've already lost momentum.
ESP was/is a lot less annoying generally. It does still kick in if you go a little crazy, and I must admit ESP does get turned off sometimes if I am in a 'bad' mood
That said I've got an LSD to help with the grip too, and during cornering + planting situations that does make a very significant (positive) difference
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 02-09-2006, 15:19   #13
Neily03's Avatar
I think you mean, 'It may save your life'
Black Magic MY07 Fabia v/RS with Cruise, Xennons, Heated Seats, Dension Ice-Link+, Aero wipers & Jabba RARB.
Neily03 is offline
Old 02-09-2006, 16:40   #14
LOL @ this thread (asr/esp) everytime it pops up
If you're spinning the wheels and losing traction you are not in control of the vehicle whether you think you are or not. The electronics do not 'cut in' annoyingly at all unless you're driving beyond available grip, which you should only do on a track or private ground. If you lose traction you HAVE ALREADY lost control, regardless of whether you think you can handle it or not.
That said I think we all have a play occasionally but it is naughty
Edit: Yes I am a grumpy fart today.
Bike with engine coming soon...
SteVRs is offline
Old 02-09-2006, 17:11   #15
Ho Hum
Mr Grumpy's Avatar
OY! that's my prerogative, you have to ask permission.
After the day I've had, I claim todays Grumpy title.
As regards asr, it's sometimes better left on, and it's sometimes better switched off, mostly on, but sometimes off, there.
I turned the light off.............
Mr Grumpy is offline
Old 02-09-2006, 17:40   #16
Briskodiodion
TeflonTom's Avatar
yeah that's what it's supposed to do but i find it effects the performance tho, you dont really need asr in a car with 115bhp!!!! marketing gimick i thinks!!
Old 02-09-2006, 17:47   #17
I'll be honest its quite handy when pulling away on a wet roundabout when listening to music as you can't hear any wheel spin...
I do indeed take it off as soon as i turn the key lol.#
edit. So why do you "drive with it on"
Old 03-09-2006, 11:11   #18
Briskodiodion
TeflonTom's Avatar
i dont!
Old 03-09-2006, 12:48   #19
But surely that's just highlighting that you can't drive a car in the wet
Chris
Old 03-09-2006, 13:44   #20
Neily03's Avatar
and you can't feel it either???
Neily03 is offline
