39,400 Members 1,487,293 Posts
Extremely good economy this morning (apparently)
This is a discussion on Extremely good economy this morning (apparently) within the Fabia I forums, part of the Skoda Model Discussion Area category; Well, for the first time in a long time my car told me this morning I got almost 75mpg on ...
Old 02-01-2008, 19:45   #1
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Well, for the first time in a long time my car told me this morning I got almost 75mpg on my way to work!
OK - It was quieter than average on my commute and much of the journey was at low speed and low rpm, but I wondered if what I tweaked over Xmas has really had the side effect of better economy.
Basically I've fitted a lightweight flywheel (so does the engine use less fuel spinning up a light SMF compared to the stock DMF) and also removed the AC, so I have a shorter 6PK auxilliary belt, just between crank and alternator.... Does the fact the aux belt usually also wrap around the AC pump perhaps imply more "effort" by the engine to drive it?? There is also the weight issue - probably saved around 10kg with the flywheel, and have knocked around 8 to 10kg off the front of the car removing the AC pump, condensor, and pipework.
Oh, the car said I also got 65mpg on my way home, but it was a bit busier, especially on the outskirts of Exeter.
Jason - Only a Skoda.
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 02-01-2008, 21:36   #2
Members Car: vRS Fabia
Re: Extremely good economy this morning (apparently)
I would imagine it's the AC pump removal thats done it. I'm sure Ross said the pump works at 10% duty to keep the refrigerant moving even when the aircon is switched off. All that said, they are some mighty impresive numbers
Rich - Black Magic Fabia vRS
vrsfab is offline
Old 02-01-2008, 21:41   #3
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
i wish i could get above 55mpg , mine is rubbish at the moment, even after the removal of the Dragon box
not so bored now
ric04vrs is offline
Old 02-01-2008, 21:45   #4
I'm back...
Mr Grumpy's Avatar
Members Car: Office chair.....
It's very rare that I even see 50mpg out of mine.
40-45 is the norm.
S50 VRS Number Plate for sale..ffs someone must want it....
Mr Grumpy is offline
Old 02-01-2008, 21:47   #5
Moderator
Bigw2069's Avatar
Members Car: Noddy Car
The flywheel will spin up easier yes, but the heavier a flywheel is the more kinetic energy it has and the more efficient it will be when kept up at speed. What we give with one hand we'll most likley take with the other
Bigw2069 is offline
Old 03-01-2008, 01:35   #6
mathepac's Avatar
Members Car: Fabia vRS
Pretty amazing - will you do mine please? 55-ish when pootling, 20's when enthusiastic.
mathepac is offline
Old 03-01-2008, 02:13   #7
Nuts
anonymouse's Avatar
You ever thought of another vocation ?
Like preaching
75mpg - you must be living on DevonUtopia
"Stupidity, if left untreated, is self-correcting." - Heinlein
anonymouse is offline
Old 03-01-2008, 02:48   #8
Moderator
Bigw2069's Avatar
Like preaching :
Hmm Reverend Big W Its got a ring, or should that be a peel
Bigw2069 is offline
Old 03-01-2008, 02:51   #9
Nuts
anonymouse's Avatar
So astute of you
Old 03-01-2008, 02:58   #10
Moderator
Bigw2069's Avatar
So astute of you
Careful, next one may be an Ambush, very Artful though
Bigw2069 is offline
Old 03-01-2008, 03:00   #11
Nuts
anonymouse's Avatar
Old 03-01-2008, 08:02   #12
Hardcore
Basil's Avatar
Technically the weight saving is correct - but you remember that post that I put up - for acceleration purposes lightening the flywheel as you have is like dropping 150 pounds of weight off the car!
Also I wonder how much energy a slightly slipping clutch loses as heat....
Glad to hear you're happy matey
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 03-01-2008, 13:40   #13
VRS_Dave's Avatar
Members Car: Skoda Fabia VRS
As Basil has said I reckon the biggest factor will have been the flywheel (although the aircon will also have made a difference). In Uni last year, I was tought that due to inertia if you were to take for example 10kg out of a car's recipricating component e.g. flywheel - it would have the same effect as taking 30kg out of a stationary component, like stripping a seat out for example.
Out of interest, I have been planning on getting a SMF and uprated clutch at some point - and is the SMF lighter that the DMF then?? If so, how much do you reckon by???
Cheers,
Dave
VRS_Dave is offline
Old 03-01-2008, 13:43   #14
didn't burn him
With the lighter flywheel, is your idle rougher than before?
Ed
I drive a Corrida Red 2004 Skoda Fabia vRS that has been retrimmed by the Seat Surgeons
Originally Posted by Frank Martin
Rule 1: Never change the deal. Rule 2: No Names. Rule 3: Never open the package.
Calculate approximate car running costs here | Support Briskoda & Join Freedom!
yegnold is online now
Old 03-01-2008, 13:56   #15
Moving Stables
skudmissile's Avatar
Members Car:
not only the most powerful fabia but also now the most economical one, keep up the good work
Run out of CASH
skudmissile is offline
Old 03-01-2008, 13:59   #16
Members Car:
Is the PD100 TDI Fabia/Ibiza Ref Sport/Polo Sport better than the vRS?
Welshy is offline
Old 03-01-2008, 14:58   #17
Moving Stables
Members Car:
And the award for the most random post of 2008 goes to welshy for this post
Run out of CASH
Old 03-01-2008, 16:52   #18
Mongreller
Images: 5
Overall (as standard), in economy terms it probably is due to lower power, yet narrow wheels to keep rolling resistance down.
Old 03-01-2008, 16:57   #19
ScoobyChris's Avatar
Members Car: Fiat Panda
As well as weighing a fair bit less too (down to not having a 6-speed gearbox, big heavy brakes and wheels I guess)
Chris
ScoobyChris is offline
Old 03-01-2008, 17:19   #20
Hardcore
Basil's Avatar
Smile Re: Extremely good economy this morning (apparently)
Also don't forget the drop in weight of the driver's right foot -
what with all the new bits running in there.....
Basil is offline
Similar Threads
Good Economy... Babs Fabia I 11 11-04-2007 23:00
Stupidly GOOD economy - MAF magic? Awed Octavia I 5 10-01-2006 13:36
Good Morning Neil.S INTRODUCE YOURSELF! First time visitors, say hello here. 5 16-04-2005 14:28
Good oil = good economy? devonutopia Maintenance & Performance 6 18-02-2005 11:13
Good Morning Matt_D INTRODUCE YOURSELF! First time visitors, say hello here. 7 07-09-2004 15:28
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
