This is a discussion on Fabia Aerial within the Fabia I forums, part of the Skoda Model Discussion Area category; Do all Fabias have the anti theft aerial or is it just the later ones? My 2002 hatch has a ...
| Briskodian Join Date: Apr 2006 Location: North East
| Do all Fabias have the anti theft aerial or is it just the later ones? My 2002 hatch has a normal removable aerial and poor radio reception, but SWMBOs 2004 estate has an anti theft type and good reception. Has someone fitted the wrong aerial to mine or is the amplifier just not working any more?
__________________ My other car is a Porsche.... |
| Skonda Fabic Join Date: Jun 2005
| Get your amplifier checked out. I think it should be the same on all models |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| As far as I know they all should be tamperproof. But the aerial amp is in the headunit and not the aerial base.
__________________ MK2 Golf GTi - APX 225bhp 1.8T - Emerald K3 - Quaife ATB - VR6 Widetrack - VR6 brakes front and rear - Neuspeed ARBs - Speedline alloys - H+R coilovers - Powerflex bushes - Helix clutch G60 flywheel - Adjustable solid top mounts - Custom engine bay - Tornado Motorsport MSA cage - and lots lots more. |
| Cheers Lummox, but I thought that the amplifier was in the aerial base and that for some reason, best known to themselves, VW or Sony powered the amp using the aerial connection on the head unit and fed power back up the aerial lead. This used to be the reason for poor reception when VW owners replaced the standard head unit but did not know that an adapter was required to power the amp. Are the Skoda aerials different to the VW ones?
| Briskodian Join Date: Dec 2005
| so how do you get the aerial off if you need to replace it?
__________________ Fabia Vrs Blackmagic! Xenons, Cruise Control, Heated Seats and ESP Wednesday 12th may 2006 was my VRS day Proper Mudflaps for VRS Clicky |
| Moving Stables Join Date: Dec 2006
| like lummox said the amp is in the headunit, so when u remove the standard one u loose the amplifier and have to replace with an autoleads adaptor or equivelent. i think they are all anti thieft from the factory.
__________________ ![]() New ??????? haha I need slippers and a pipe with this one. but it might be a real sleeper ![]() Gone..... 226bhp + 382lbft ![]() Fabia vRS + Stage 2 hybrid now on lowered suspension goes like a missile |
