Fabia RS Driveshafts...
This is a discussion on Fabia RS Driveshafts... within the Fabia I forums, part of the Skoda Model Discussion Area category; Are they standard across the range or RS specific? how much are new ones?...
Old 18-02-2006, 21:18   #1
UberMod™
Neo_VR's Avatar
Default Fabia RS Driveshafts...
ColGod the UberMod
VXR, Gti, ST, vRS, Shifty... An MPS fears not these things...
Neo_VR is offline
Old 18-02-2006, 21:23   #2
Hairy Yeti
Lummox's Avatar
Default Re: Fabia RS Driveshafts...
Ask Jason, he will be finding out soon enough
But yes RS specific as the six speed box has different sized output flanges.
Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 18-02-2006, 21:24   #3
Briskodaholic
Tom_vRS's Avatar
If you hadn't posted Col, I would
97/R BMW 328i in Boston Green.
<< Clickable for boring info.
My Journal
Tom_vRS is offline
Old 18-02-2006, 21:38   #4
Mongreller
devonutopia's Avatar
Ross! You asked for that.
DON'T TALK TO ME ABOUT F***IN' DRIVESHAFTS!
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 18-02-2006, 22:02   #5
130bhp
Josh_PoloGTi's Avatar
Driveshafts are meant to break if the load gets too crazy...
Much better for the driveshaft or CV to break, rather than a diff/box.
Originally Posted by Goochie View Post
Some say that if you break him in half he has a hard white centre with red writing though it.
Some say this writing says "JBS Auto Designs"
All we know is, that he's called The Josh!
Josh_PoloGTi is offline
Old 18-02-2006, 23:48   #6
Briskoda Staff
VRStu's Avatar
Looking at about £228 + Mafia Tax for a complete one with CV joints Colin.
As Ross says, only ASZ for the application.
Stu - Freedom Pimp
Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone.
Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats.
VRStu is offline
Old 19-02-2006, 00:22   #7
bpm
Drink me!
bpm's Avatar
BPM
This is a website , NOT a mobile phone.
STP USNG TXT SPK
bpm is offline
Old 19-02-2006, 10:20   #8
Jimb0's Avatar
So there is a difference between the Fabia vRS d/s and the normal fabia d/s?
If so, jason, did you have the 1.9tdi kit in yours or the vRS kit?
Would the vRS kit be able to cope with 360lb/torque better than if jason was running the standard setup?
(If that makes sence)
Jimb0 is offline
Old 19-02-2006, 10:30   #9
Mongreller
Yup - large differences, PD130 dirveshafts are a lot chunkier in the shaft bit, and I assume the CVs are too. They're also slightly shorter as the 6 speed box is wider than the 5 speed, so both driveshafts have to be made shorter.
There was no way I could use the pd100 driveshafts as spares as they'd be the wrong size and likely to not have the same tolerances as the pd130 ones,
I was using pd130 shafts when the inside one blew a joint. The offside one is brand new as the driveshaft had already been nabbed at the scrappy before I got in there. Perhaps in foresight it would have paid for me to get both shafts brand new and not risk a second hand one from a scrapped car? Never mind.
Old 20-02-2006, 12:28   #10
Jimb0's Avatar
heh lesson learnt, hope you're back on the road soon son
Jimb0 is offline
Old 20-02-2006, 15:17   #11
Escorted Estate
Out of interest, are there any uprated ones available? Just getting concerned due to the expected extra power delivery I'll end up with. Also will the Quaife LSD make this problem worse/better?
WW --->> Project Journal (pic links in first post there)
Fabia vRS alloys for sale incl tyres, spare wheel with tyre + spare tyre - make me an offer via PM
WW_VRS is offline
Old 20-02-2006, 15:26   #12
Mongreller
Don't let my busting incident put anyone off.
If anyone remembers, both outer hubs I got with my conversion were knocked out of alignment by 5 degrees or more. With a knock like that to the outer hub, I'm reckoning something could easily have fed through to the driveshaft joint/s. Makes me worry about the outer joint a little on the shaft too...
Offside shaft is brand new so I have no worries about that one. But the fact I have doubts about this driveshaft is making me think strongly about getting a spare complete nearside shaft from a good source.
Old 20-02-2006, 15:28   #13
UberMod™
Neo_VR's Avatar
And also dont forget that Jason was doing pretty much the most extreme torture you can give your transmission...
if you plan to be doin the 'pod reguarly.. youd be better off with a different car!
ColGod the UberMod
Neo_VR is offline
Old 20-02-2006, 15:33   #14
Escorted Estate
Mine will be doing the motorway runs to work/back again mostly, with a bit of fun on B-roads and roundabouts when I fancy it. Won't be doing any form of track or 'pod - suppose I'm just paranoid
Second thing to add to the list of stuff I don't want:
1. Broken drive shafts
2. Jason's smokescreen - btw Jason did you get the new 'zorst & if so did it make things better than the straight-through pipe you've currently got/used to have?
WW_VRS is offline
Old 20-02-2006, 15:54   #15
Mongreller
1) shouldn't happen again.
2) new straight thru pipe is better than old straight thru pipe which was essentially just a bolted in bit of pipe to replace the cat. It is now full stainless pipe from DP to tailpipe with no boxes. It is much more efficient but boy it makes a funny noise at tickover. Smokes less in general I found, but it was still capable of leaving great clouds of soot on the A46.
Old 20-02-2006, 16:58   #16
Escorted Estate
- fair enough & thanks for letting me know. I reckon SWMBO would notice that kinda smoke screen you see & have a few words as to why that's happening
WW_VRS is offline
Old 20-02-2006, 17:01   #17
Mongreller
The noise too. At a constant 90mph, I mean 70mph it has a permanent rumble in the background (when pushing constant 0.5bar to keep that speed up). I don't mind this but in this day & age of silent exhausts and quiet engines / padding, it may not be so desirable.
Old 20-02-2006, 17:19   #18
class37's Avatar
Is your fabia Lowered , and if so how much ?
Had a Vauxhall caviler that was lowered 60 mm, I was for ever blowing cv joints
Bike Kawasaki ZX10 R
NW
class37 is offline
Old 20-02-2006, 17:22   #19
Escorted Estate
I'm not allowed to go to 3 digits when SWMBO is in the car (kph ) and I must admit I rarely go that fast anyway, but I'll keep it in mind
Mine should be a little less noisy I hope as it's the BF one and it still has a cat
WW_VRS is offline
Old 20-02-2006, 19:36   #20
Mongreller
Well, in the fabia dropping the car actually appears to straighten out the driveshafts a little bit. If this is a good or bad thing, I don't know.
Mine's dropped around 65/70mm st the front from standard.
