This is a discussion on Fabia Std brakes a warning. within the Fabia I forums, part of the Skoda Model Discussion Area category; Just took std fronts to bits, thought i had a stone stuck, but found all 4 friction linings detatched from ...
| Briskodian Join Date: Aug 2004 Location: Central Scotland
| Just took std fronts to bits, thought i had a stone stuck, but found all 4 friction linings detatched from backing plates, std pads with around 5000 miles on them 6.5 mm lining left, i'll be writing to Skoda tomorrow. One lining had disintigrated and that was the noise problem. Disc is also knackered where lining self destructed. ![]() ( Fabia vRS ) |
| Briskodian Join Date: Apr 2004 Location: sheffield
| That sounds bloody scary!!!!!!!
__________________ Artificial Intelligence is no match for Natural Stupidity |
| doesn't sound to good that
__________________ not so bored now |
| they should replace those for free..
__________________ vorsprung durch czechnik |
| Briskodian Join Date: Jun 2005 Location: kent,uk
| goes to show for batch quality. 42k miles on mine! & i'm just looking at replacing the lot. (uprating of couse). They ought to replace them but don't bet on it, brakes are seen as consumables and not covered as standard. |
| Skoda UK have them now, lets see what happens. |
