This is a discussion on Fabia VRS 18" alloys within the Fabia I forums, part of the Skoda Model Discussion Area category; Just wondering if 18" alloys will fit fabia vrs with no problems. also, when eibach springs are fitted, is there ...
| Briskodian Join Date: Feb 2006
| Just wondering if 18" alloys will fit fabia vrs with no problems. also, when eibach springs are fitted, is there still problems/no problems. I will not affect the speed with 18" alloys will it ? thanks Richard |
| Briskodian Join Date: Feb 2006 Location: West Midlands
| People have fitted 18s but I am not sure what other mods (if any) were needed. You'll have to wait for another response or use the search function to find out details ![]()
__________________ Xbox 360 gamertag: TexasJohn74. |
| Briskodian Join Date: Sep 2005 Location: Cumbria
| Shifty had 18" alloys on his Furby. You can see them on his signature. Maybe a little PM to him might help (or just wait, I'm sure he'll be along for some good advice)
__________________ Jon. |
| Briskodian Join Date: Jul 2003 Location: Under The Bonnet
| No problems with mine on eibach springs. May get some when the coilovers go on though. ![]()
__________________ Octavia VRs mk1 |
| Briskodian Join Date: Aug 2005 Location: Aachen/Germany
| ![]() Fitted my 18s on my Fabia with coilovers two days ago. front: 8x18 ET 35, needed arches modification and cutting of the plastic housing inside rear: 9x18 ET 30, no modifications needed Alloys are Rial Nogaro with 215/35 R18 tires. It doesn't affect speed, the speedo is just more accurate (proofed that with my GPS). But it certainly does affect acceleration. |
| That looks AWESOME!!!! What is it that effects acceleration? Is it simply down to an increased contact patch? ![]() |
| | #7 | |
| Quote:
__________________ ![]() | |
| | #8 | |
| Quote:
| | #9 | |
| Quote:
If that's the case the only way it will have an affect is the slightly higher unsprung mass and the slightly larger friction co-efficient which will actually help you get away quicker
__________________ ![]() Last edited by Bigw2069; 16-04-2006 at 22:49. | |
| | #10 | |
| Quote:
More unsprung weight, maybe? (just guessing)
__________________ Xbox 360 gamertag: TexasJohn74. Last edited by texasjohn; 16-04-2006 at 22:48. | |
| | #11 |
| It will be weight that will do it. Rollig radius is the same as a lower profile tyre is used. Markus your car looks the dogs danglies.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| | #12 | |
| Quote:
My BBS alloys are lighter than the std vRS ones, and only 1" wider (215 tyres instead of 205 needed). So fingers crossed there isn't a noticeable difference in performance. | |
| | #13 |
| Briskodian Join Date: Apr 2004
| not bad
__________________ FabiaGT 2.0 8x18 A8 s-line Wheels , KW-Suspension Var.2 , Bastuck V2A Exhaust System, ..................... Last edited by fabiano; 16-04-2006 at 23:25. |
| | #14 |
| Rolling radius is definitely slightly bigger, that's why the speedo is in fact more accurate now. Loss of acceleration comes due to a physical phenomenon which is called "moment of inertia" in english I think. In fact not only the weight of the wheel affects acceleration but also the weight distribution (more mass on a larger radius). |
| | #15 |
| so does it affect acceleration a lot ? or is it not very noticable ? i think Monkey boys car looks a little high (no offence meant) Markuss car looks good with the coil overs but what price would i be looking at +fitti ng and what coilovers are they ? i got a quote from demon tweeks for eibach springs + fitting = £350 (eibachs were £150 without fitting) thanks |
| | #16 |
| It's noticable when accelerating at higher speeds. From a standing start you will hardly notice any difference I think. |
| | #17 |
| Coilovers are a pain in a way - they definitely look fantastic when lowered like that, but on my daily drive I'd scrape the sumpguard daily due to the roads I drive on ![]() Eibachs is as low as I'm prepared to go for general driving. No argument on the looks though, I reckon those 18" + coilovers look excellent ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #18 | |
| Briskodian Join Date: Aug 2005 Location: East UK
| Quote:
What is the effect on top speed? edit: Also, if speedo is more accurate, you may have slightly higher gearing by maybe 3% which will knock 3% off your acceleration in any gear as well. Chris
__________________ Red Fabia vRS. Gone but not forgotten .Chilli Red / white Mini Cooper Diesel with dual controls. Silver 53 MR2. Mods: PPE 4>1 manifold | PPE Mangnaflow high flow cat | Blueflame catback exhaust | Pikey inlet mod | 3.0 Racing Chassis stiffening brace kit | BC Racing fully adjustable coilovers | TF loud. Details here My MR2 Page Last edited by Chris GB; 17-04-2006 at 12:28. | |
| | #19 | |
| Quote:
