This is a discussion on Front wishbone/console bush part number within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi, Has anyone got a part number for a front wishbone/console bush for a Fabia vRS? I understand that you ...
| Briskodian Join Date: Dec 2003 Location: Bolton
Members Car: Fabia vRS Thanks: 36
| Front wishbone/console bush part number Hi, Has anyone got a part number for a front wishbone/console bush for a Fabia vRS? I understand that you can fit Seat Cupra bushes, has anyone got a part number for these too and maybe a price so i can see the difference? One of mine has split and is squeeking like hell! Thanks... |
| | #2 | |
| Briskodian Join Date: Sep 2004 Location: South Bucks
Members Car: Fabia vRS and Impreza P1 Thanks: 16
| Re: Front wishbone/console bush part number Quote:
Miaaooow <BANG!> "A kitten is killed every time you don't use the search facility". And you asked two commonly asked questions. ![]() I don't have the numbers to hand. They're on this site or or Stu's site. The ever helpful and handy Fabia-vrs.com - Home Page HTH J.
__________________ Slowly turning the planet sooty. | |
| The Following User Says Thank You to vindaloo For This Useful Post: | helpmedisappear (19-11-2007) |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 209
| Re: Front wishbone/console bush part number note - if its the front bush - Skoda recommend you change the whole wishbone. Powerflex makes easy to drop in uprated replacements for those. Rear bush is the cupra jobby - what he said - fabia-vrs.com (think it was 8 quid IIRC) Good luck
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| The Following User Says Thank You to Basil For This Useful Post: | helpmedisappear (19-11-2007) |
| Re: Front wishbone/console bush part number Thanks...its the front bush thats gone, so i was going to replace both front bushes at the same time using your how to Basil. Is this info correct from Stu's site: SEAT Cupra PD160 Console Bush (Available From SEAT Dealers) 6LL 407 183 Rubber Mounting (£7.78) Thanks |
| Re: Front wishbone/console bush part number Just to clarify after some digging, the bushes i need are the front wishbone rear bush! Is 6LL 407 183 the right part number for these? Thanks |
| | #7 | |
Members Car: silver Fabia VRS Thanks: 31
__________________ very bored and liable to do something stupid | |
| The Following User Says Thank You to ric04vrs For This Useful Post: | helpmedisappear (19-11-2007) |
| Wishbone bush | Silver Surfer | Octavia I | 7 | 23-09-2007 21:06 |
| Front wishbone console bush - pressing out? | Griz | Fabia I | 17 | 13-09-2007 21:23 |
| Std wishbone bush P/Ns and prices | Wardy | Fabia I | 8 | 21-06-2007 08:29 |
| Fabia wishbone rear bush help please | fabiadmirer | Fabia I | 16 | 28-05-2007 15:49 |
| Fabia vrs front os console bush. | skudmissile | Fabia I | 14 | 25-02-2007 01:40 |
