This is a discussion on Fuel Cap Prob! within the Fabia I forums, part of the Skoda Model Discussion Area category; ok got my new vRS on the 1st and filled it up for the 2nd time tonight went to close ...
| Briskodian Join Date: Jan 2006 Location: Kent
Members Car: Fabia vRS Thanks: 0
| Fuel Cap Prob! ok got my new vRS on the 1st and filled it up for the 2nd time tonight went to close it and it wont, itsnt falpping when driving or anyhting like that just wont click back in, i searched the forums and saw it a common problem but not how to fix it..... and help would be appriciated ![]() would it have anything to do with me trying to pull up the realease with the door still closed? (forgive me im still getting usted to it lol) ![]() |
| Briskodian Join Date: May 2005 Location: A hop and a skip from nowhere
Members Car: Fabia vRS - Black Thanks: 3
| Re: Fuel Cap Prob! need a cable tie -metal type is best - anything to hold the two plastic parts together... Open up drivers side rear light carpet stuff and you will see it has popped out of place. Be resourceful and find something to fix them together. OR... take it back to dealer and they will do it for you... With a gose pipe connector thingy... HTH
__________________ ![]() Fabia v/RS http://www.whf.org.uk Wildlife Heritage Foundation - The Big Cat Sanctuary in Kent. Part of the European Endangered Species Programme (EEP) Big Cat Encounter - Want an idea for a great present?? Last edited by Sonic1980; 06-03-2006 at 20:59. |
| Briskodian Join Date: Jan 2004 Location: North East England
Members Car: SEAT Leon TDI Sport Thanks: 34
| Re: Fuel Cap Prob! The spring loaded cable pops out of the flap catch (ohhh!!). I think Sonic1980 means fix it with a jubilee clip.
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! John Cooper Works airbox, Superchips Bluefin remap, Sprint Booster, 17" Cooper S Spokes |
| 130bhp Join Date: Dec 2003 Location: Sheffield (UK)
Members Car: Skoda Fabia vRS Thanks: 0
| Re: Fuel Cap Prob! Open your boot, undo the carpet on the right hand side of the boot. You will see the cable that curls round to the filler cap mech. Just push this back into the socket, then blob a bit of hot glue or something over it so it doesn't pop out again. |
| The Following User Says Thank You to Josh_PoloGTi For This Useful Post: | Mintyfresh (17-08-2008) |
| Briskodian Join Date: Sep 2004 Location: Leicestershire
Members Car: Smart Roadster Coupe Brabus Thanks: 4
| Re: Fuel Cap Prob! It's a pain in the *** - I've been ultra gentle with mine since it went and it's been fine - just try to swing on it a bit less!
__________________ Engined bike. Engined car. Neither a Skoda - been there, done that |
| Briskodian | Re: Fuel Cap Prob! The benefits of using search..... my filler cap wouldn't shut last night, a few minutes on here and 30s to fix. cheers matt. |
| Re: Fuel Cap Prob! Glad we could all be of help. A problem shared etc...!
__________________ ![]() Fabia v/RS http://www.whf.org.uk Wildlife Heritage Foundation - The Big Cat Sanctuary in Kent. Part of the European Endangered Species Programme (EEP) Big Cat Encounter - Want an idea for a great present?? |
| Briskodian Join Date: Jun 2006 Location: Garden of England
Members Car: 06 Fabia Vrs Thanks: 0
| Re: Fuel Cap Prob! Thanks to the forum collective problem solved, what a weak looking part !
__________________ 06 Fabia vRS. |
| | #10 |
| Briskodian Join Date: Jun 2006 Location: Exeter
Members Car: Fabia 1.9TDi Elegance Estate Thanks: 0
| Re: Fuel Cap Prob! This is a common problem which the dealers fix with some sort of adhesive but I think the cable tie suggestion sounds better. Probably caused by pressure on the catch from the petrol pump nozzle when filling up. Try to park with the petrol pump on the same side as the filler cap or at least avoid stretching the hose across the back of the car as this will apply pressure to the catch. |
| | #11 |
| Briskodian Join Date: May 2004
Members Car: Fabia 1.4 estate 2004 Thanks: 0
| Re: Fuel Cap Prob! Could someone please advise how to remove the carpet inside the boot on the right where the filler cap is located because I've just looked at mine and it's not immediately obvious how I should proceed. I don't want to damage the carpet so would appreciate step by step instructions if poss. Thanks |
| | #12 |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Re: Fuel Cap Prob! Just pull it out from behind the plastic trim which goes around the area behind the taillights. It should pop out from behind the trim with some persuasion. Then a hand can be put in, and re-clip the fuel filler cap cable into position. ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| | #13 |
| Briskodian Join Date: Jan 2007 Location: Burton on Trent
Members Car: Fabia VRS Thanks: 0
| Re: Fuel Cap Prob! Mine has just been back to the dealer today for the exact same problem, the warranty sheet says that they refitted teh cable and mechanism. |
| | #14 |
Members Car: Audi S3 Thanks: 195
| Re: Fuel Cap Prob! There is an ingenious official fix for this now
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #15 |
| Re: Fuel Cap Prob! The fuel cap problem is caused by excessive pressure on the mechanism when filling the tank. Avoid stretching the hose from the pump across the car when filling up, better to park with the filler cap on the same side as the pump. Hope I do not appear to be telling you "how to suck eggs", but I speak from experience. |
| | #16 |
| Briskodian | Re: Fuel Cap Prob! Just came across this thread - Thanks to everyone who has posted. What are you meant ti secure the cable with? Can electrical tape be used? Is so what portion of the picture above should you tie up? |
| | #17 |
| Briskodian Join Date: Sep 2004 Location: South Bucks
Members Car: Fabia vRS and Impreza P1 Thanks: 16
| Re: Fuel Cap Prob! In Stu's 2nd piccie, a small jubilee clip is used to reinforce the joint. So it shouldn't pop out again.
__________________ Slowly turning the planet sooty. |
| | #18 |
| Briskodian Join Date: Oct 2005 Location: Chepstow, South Wales
Members Car: 2006 Fabia vRS - Black Magic Thanks: 0
| Re: Fuel Cap Prob! *Just a side note; Noticed when i did this last night it didn't work unless i was holding the filler flap shut.
__________________ Wales' most Easterly Briskodian ;-) |
| | #19 |
| Briskodian Join Date: Feb 2007 Location: derbyshire
Members Car: black fabia vrs Thanks: 38
| Re: Fuel Cap Prob! Had this on mine for a couple of days and was fed up but BRISKODA triumphs again and its sorted within seconds ![]() Posted reply so others can see it and be prepared for it happening to them ![]() What next leaky door cards? ![]() ![]() PS think those pics from vrstu look like big pink cable operated buttocks ![]() |
| | #21 |
| Briskodian | Re: Fuel Cap Prob! As per VeeKar and mw2655 - found this problem after filling up the car today and was thinking a long trip to Glasgow was in order for fixing at the dealers. Fortunatly; BRISKODA forums, a quick search and a 1 minute faff around the boot as described above got this sorted. Thanks to all for the advice - BRISKODA proves it's usefulness again |
| | #22 |
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
Members Car: 04 Fabia vRS (180/300) Thanks: 28
| Re: Fuel Cap Prob! I also used this thread about 2 months ago.
__________________ '04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints |
| | #23 |
| Another Voice Join Date: Nov 2007 Location: Nr. Boston
Members Car: Fabia vRS 179.8 BHP Thanks: 19
| Re: Fuel Cap Prob! I've just used this thread too. I can't believe how many common fault these fabias have! If only I could fix my damned leaky doors!! If anyone's struggling it's dead easy to just pop off the top two holders for the carpet, feel around the furtherest part of the car near the rear light and you'll find a kind of cable thing... this'll be attached to a spring, which will have fallen out of place. Just pop that back in and job done. if it comes out again I'll get some super glue to it!! |
| | #24 |
| Briskodian Join Date: Jan 2005 Location: P'boro / King's Lynn
Members Car: Fabia 1.9 TDI Elegance Thanks: 10
| Re: Fuel Cap Prob! Thought I would let you know I broke the black plastic end piece when trying to fix mine (the one the cable slides in) skoda sell this part for 26p inc vat It was difficult to fit the cable into the new one with the spring forcing it away all the time so I used pipe cleaners to hold the spring 'shut' and it was then easy. |
| | #25 |
| Briskodian | Re: Fuel Cap Prob! I wrapped duck tape round the joint and it`s been fine since and that`s 2 years now.
__________________ 2002 Fabia 1.4 16v 100bhp 2006 Gilera Nexus 500 |
