Fuel filler flap
This is a discussion on Fuel filler flap within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi, Does anyone know where I can get the spring that pushes the fuel filler flap on 2002? I have ...
Old 21-11-2007, 14:56   #1
POW
Default Fuel filler flap
Hi,
Does anyone know where I can get the spring that pushes the fuel filler flap on 2002? I have lost mine. BTW what is it called?
Cheers
POW is offline
Old 21-11-2007, 21:21   #2
Default Re: Fuel filler flap
Retaining Spring, p/n 6Y6809857 ?
check vagcat.com and have a look for yourself, you will need to register to use it.
hibby is offline
The Following User Says Thank You to hibby For This Useful Post:
POW (22-11-2007)
Old 22-11-2007, 15:21   #3
POW
Many thanks hibby
Fabia 1.9DTi on 2002
POW is offline
Old 22-11-2007, 16:22   #4
Mongreller
devonutopia's Avatar
Are you sure the connector has not just become disconnected from the inside? This is the usual cause of the fuel filler cap not actually closing fully shut.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 22-11-2007, 16:51   #5
hardcore modder
Basil's Avatar
what he said - before anything else pull back the boot carpet trim and look at the little cable at the flap.
Often it pops out and doesnt work. Tape/wire ties it in it's little connector (you'll see what I mean).
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
The Following User Says Thank You to Basil For This Useful Post:
McScooby (23-12-2007)
Old 23-12-2007, 10:37   #6
McScooby's Avatar
HTH
Bas
Thanks for this Basil, just what was wrong with mine just.
Who says the search feature is useless.
There are 11 types of people who understand binary.
McScooby is offline
Old 23-12-2007, 10:48   #7
bluebeat's Avatar
Mine did it yesterday remedied it from this site
bluebeat is offline
Old 12-02-2008, 11:04   #8
skodastream's Avatar
yep mine had done this and can confirm that the wire wiggling worked a treat
skodastream is offline
