This is a discussion on get fuel out?????? within the Fabia I forums, part of the Skoda Model Discussion Area category; bottom...
| Briskodian Join Date: Nov 2004
| bottom Last edited by bugman; 04-09-2006 at 22:56. |
| Briskodian Join Date: Feb 2005 Location: A30 Newquay Cornwall
| put petrol in have you ?
__________________ ![]() Fabia Bohemia Mods - 16" BBS Montreal's, Blaupunkt Rome nav, fitted front and rear areo wipers, rear OEM speakers fitted, vw damped grab handles. |
| Briskodian Join Date: Dec 2005 Location: South east
| We had this with petrol that was put in a diesel passat, lifted the rear bench, opened the fuel pump hatch to gain access to the tank, put a 15mm pipe into the tank, almost to the bottom, then put a hoover at your end and turned the hoover on untill the fluid come out throught your end, take hoover tube away and let contents flow out by itself. |
| ECUless Join Date: Mar 2005
| Take the tank unit out and either pump or syphon it out. |
| Or take the supply pipe off the fuel filter, put 12v to the lift pump and let that pump it out.
__________________ Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| iv Last edited by bugman; 04-09-2006 at 22:57. |
| There is a special tool but a wide screwdriver and a tapping stick should get it moving.
| it? Last edited by bugman; 04-09-2006 at 23:02. |
| ????????????? Last edited by bugman; 04-09-2006 at 22:59. |
| | #10 |
| Briskodian Join Date: Jun 2004 Location: Oxford
| I may be mistaken, but i thought that with modern diesels, getting rid of the fuel in the tank was the least of your worries, isn't there a good chance that the fuel pump is damaged? |
